Driveline questions
Old May 22, 2012 | 08:00 PM
Vettefied's Avatar
Vettefied
Default Driveline questions
I have been looking through some corvette catalogues to see what parts are interchangable throughout the C3 years just out of curiosity.
What I am wondering is how much torque/HP can a stock driveline take? I have heard of people upgrading driveshafts and half shafts, but at what point do you need to take it into consideration?
I am just curious, my L48 will be no where near that "limit" whatever it is.
Thanks guys.
Old May 22, 2012 | 08:31 PM
72SLEEPER's Avatar
72SLEEPER
Sorry, don't have the answer but would like to know too. I am positve this will start a good discussion
Old May 22, 2012 | 09:24 PM
gcusmano74's Avatar
gcusmano74
The short answer is, plenty. But.
If you drive your car in an adult fashion, and start and shift smoothly, the C2/C3 drivetrain will easily handle a lot of power.
If you want to dump the clutch at 5000 RPM all the time, and bang your way through the gears, you will very quickly begin driving over some parts. Guaranteed.
Basically, if you treat your car as a sports car, it will last a good long while. As a dragster, not so much.
Old May 23, 2012 | 05:20 PM
Vettefied's Avatar
Vettefied
How much is pleanty? Beauty is in the eye of the beholder right?!?!?!
What is considered the weekest link in the driveline?
Old May 23, 2012 | 05:39 PM
gkull's Avatar
gkull
The stock driveline is very strong. Years of drag slicks and shifting my 427 at 7500 rpm with racing 700R4 tranny. It never had a problem and was 25 years old
The weak links are: the posi unit case, The yokes, early smaller diameter half shafts and u-joints, outer spindles. Once my originals went bad or broke I replaced them with some of the best parts made.
I changed to a 5 speed and a driveshaft with 1330 u-joints and I put a cage around it for safety.
Now I only destroy the $800 posi units from Tom's Differentials and the HD outer spindles about every 4 years
Old May 29, 2012 | 03:39 PM
Vettefied's Avatar
Vettefied
So 400hp is not at all a concern for a stock driveline, even the 75 (lowest hp of all)?
What is the difference in half shafts between these?
68-74
75-79
80-82
Corvette America has them listed as seperate parts for each of those groups. Is one stronger than the others?
Also what components are you guys using as upgraded versions of each part?
Old May 30, 2012 | 01:36 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
68-74
75-79
80-82
63-74 - 2.5" Shafts
75-79 - 3" Shafts
80-82 - 3" Shafts but there is a diff between auto & 4 spd and all 82's take the same u-joint. These are also shorter and will not work on a 63-79 car.
Stick with the 3" shafts you have and throw some Spicer U-joints in and call it good.
Old May 30, 2012 | 02:45 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...What is considered the weekest link in the driveline?...
The driver.
To Driveline questions
