It's been a long road restoring my father's 1979 corvette. With your help, I've gotten it back to an amazing condition. I know if he were still here, he'd be so proud of it!
One of the last few things I need to fix are electrical issues. As of right now, I cannot get the headlights to turn on. I thought it was simply a fuse but I don't even think there is a headlights fuse. Is there? They were working a couple of months ago. I did take off the dash and unplugged the headlights switch but the other lights turn on when I pull the switch... What are some places I can check? Thank you all in advance!
Do you mean that the lights don't go on or they do not raise? The lights are raised and lowered on vacuum power. Did you disconnect a vacuum line when you have the dash apart?
Woops, I should have been more specific. The lights themselves do not turn on. I do have a vacuum leak as well that needs to be addressed, in addition to this problem. Thanks for your reply!
