71 wiper door wont open
Old May 25, 2012 | 01:29 PM
conway62's Avatar
conway62
Default 71 wiper door wont open
When I turn on the wipers, the wiper door opens about and inch and stops. I shut the switch off and it closes normally. Never had any problems with this before. Any thoughts? Nothing has been disconnected or changed from when it was working.
Old May 25, 2012 | 02:26 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Sounds like something is binding....check the linkage and try to spray a lubricant to free it up.
Old May 25, 2012 | 02:31 PM
Roco71's Avatar
Roco71
Could the door be caught on a washer hose?
Old May 25, 2012 | 02:55 PM
Alan 71's Avatar
Alan 71
Hi c62,
Perhaps you can remove the black rubber plug in the forward side of the door actuator. You can then put a screwdriver in the opening and carefully push on the actuator's diaphragm. If you can easily push the door open you'll know the mechanism is free and the problem is a control or servo problem.
Good Luck!
Regards,
Alan
Old May 25, 2012 | 03:53 PM
conway62's Avatar
conway62
Thanks guys, Ill check it all tonight.
Old Jun 5, 2012 | 02:31 PM
conway62's Avatar
conway62
Working great now. It was the rubber seal (witches hat). The coned shaped portion ripped itself from the base. Couldnt see it unil I took it apart. Its got to be the lowest cost repair I have ever done. 30 min and 12 dollars to fix it. Works awesome now.
- Ron
To 71 wiper door wont open
