Help with driveshaft installation, please?
Old May 27, 2012 | 05:21 PM
C3Paul's Avatar
C3Paul
Default Help with driveshaft installation, please?
Ok,
This may be a silly question, but here I go:
Just fitted my new engine and transmission in to my car and now I need to fit the driveshaft, but I am unsure which way it goes in.
Before disassembly I have marked the driveshaft front and back, but did not mark which way it was connected (u-joints) to the transmission and differential.
As long as I connect the marked front of the driveshaft to the transmission and marked back of the driveshaft to the differential, does it matter which way I connect the ujoint to the transmission and differential yoke?
While I am at it I would like to replace and upgrade the original u-joints with some heavy duty ones to handle my new 500ft torque engine.
Which yokes would you recommend and how best to connect the driveshaft to minimize vibrations?
BTW my car is 1980 with 4-speed super T10 transmission
Thank you
Old May 27, 2012 | 06:14 PM
jachin99's Avatar
jachin99
It doesnt matter as long as the ears are aligned on the driveshaft and slipjoint.
Old May 27, 2012 | 06:22 PM
scottyp99's Avatar
scottyp99
Originally Posted by C3Paul
Ok,
Does it matter which way I connected as long as I have the front and back correct?
Thank you
I have no idea what you mean by this, can you explain it a different way?
Keep the shiny side up!
Scott
Old May 27, 2012 | 06:41 PM
C3Paul's Avatar
C3Paul
Scott
Old May 27, 2012 | 06:59 PM
...Roger...'s Avatar
...Roger...
Doesn't matter,but in the future if your car is vibration free,mark it and put it back the way it came out.
Old May 27, 2012 | 07:06 PM
Mike Ward's Avatar
Mike Ward
Old May 27, 2012 | 07:29 PM
Mooser's Avatar
Mooser
If you do notice a vibration, maybe turn it around 180 just in case it was remarkably balanced with the pinion-yoke before you start chasing any deeper issues
For U-Joints, hard to beat the solid spicers
Mooser
Old May 27, 2012 | 09:45 PM
scottyp99's Avatar
scottyp99
Hmmm. I guess what's confusing me is that I only know one way to do it.
Scott
Old May 28, 2012 | 08:06 AM
gkull's Avatar
gkull
Is it driving yet?
Old May 28, 2012 | 12:10 PM
C3Paul's Avatar
C3Paul
Hi George,
Almost there.
The engine went in on Saturday with quit ease, but it took almost forever to install the transmission!
Despite of the fact that I have used an alignment tool to align the clutch discs with the pilot bearing I still straggled.
All connected now.
I am going to replace my u-joints and have the driveshaft balanced as well.
Now the small stuff:
Passenger header is touching steering idler arm
Need to fabricate fuel line with inline fuel filter
Still missing valve cover breathers
Have not a clue at all, where and what vacuum lines should be or where they go
Need to fabricate centre exhaust section to fit through my double hoop transmission crossmember.
Adjust clutch and shifter linkage
Carburettor installation kit and throttle linkage
I am sure there is still more to come
Old May 28, 2012 | 01:23 PM
Mike Ward's Avatar
Mike Ward
1) Detach drive shaft from differential yoke.
2) turn drive shaft 180 degrees.
3) reattach to diff. yoke.
4) repeat 1-3 at transmission yoke.
Old May 28, 2012 | 01:25 PM
gkull's Avatar
gkull
Hi George,
Almost there.
All connected now.
Sometimes you have to dent headers
You can find a vacuum line C-3 diagram online. Stock units "T" off the large 3/8th line going to the power brake vacuum canister.
Custom mod your crossmember to make it a cross under.
Clutch linkage, so you have an inch or so pedal movement before it actually starts to dissengage
the carb.............. use studs to mount it without gasket sealant
Old May 28, 2012 | 03:38 PM
scottyp99's Avatar
scottyp99
Do you really think that is what the OP is asking? I've never paid any attention at all to which way the driveshaft goes back in.I can't see how it would make any difference at all. Kinda like asking "Which is the right cylinder head, and which is the left cylinder head?". I wouldn't call it a dumb question, though, if you are not sure about something, it's always smart to ask.
Some of the replies are making a lot more sense to me, now! I guess I'm the one who is a little slow on the uptake!
Scott
Old May 28, 2012 | 05:33 PM
7T1vette's Avatar
7T1vette
The driveshaft and differential are 'marked' for orientation from the factory. Whether you keep it that way or not is 'no big deal'; but, if the differential yoke is indexed 180* [relative to the U-joint], either way, it might have less vibration.
Old May 28, 2012 | 10:08 PM
Mike Ward's Avatar
Mike Ward
Yup.
Old May 29, 2012 | 03:20 AM
C3Paul's Avatar
C3Paul
Ok, sorted now
Next question?
The driveshaft is not indexed
Found a driveshaft shop who are able to replace my u joints with new nongreaseble HD ones and can balance my driveshaft as well.
Is it worth having the driveshaft balanced with the new ujoints but without the yokes as they are still attached to the transmission and diff.
So all they will do is to ballance the driveshaft with new ujoints
Isn't this like balancing a crank without the flywheel and balancer?
Do it or not?
Old May 29, 2012 | 06:55 AM
Mooser's Avatar
Mooser
It's not going to hurt but I'd doubt there's a problem there, I have it done with at least the trans yoke.
Mooser
PS, 1/2 shafts could use it, and new u-joints "While your at it". Those U-joints see a lot more movement than the drive-shaft
To Help with driveshaft installation, please?
Old May 29, 2012 | 09:54 AM
C3Paul's Avatar
C3Paul
Had another chat with the prop shop owner (really helpful guy) and he suggested that I remove the yoke from my transmission and get the prop shaft balanced with new u joints and the transmission yoke as one unit.
How do I remove the yoke from my Super T10?
I hope I do not have to remove the transmission from the car in order to remove the yoke?!
BTW: I am not doing the 1/2 shafts before I burn some rubber and brake the 1/2 shafts
Been tooooo long
Old May 29, 2012 | 10:49 AM
MIKE80's Avatar
MIKE80
Been tooooo long
Unbolt both ends of the driveshaft, push the yoke into the trans, drop the driveshaft out of the way. The yoke just slips out of the trans.
Old Jun 17, 2012 | 04:32 PM
gkull's Avatar
gkull
Well is it runnin yet? I was just watching the Moto GP from Silver Stone and thought of you.
Those super smooth tracks with big run offs would be fun to run the vette on
