What should I do?
I have an 80 that was given to me about a month ago from my sister, a very nice car and I would like to do some modifications to it to make it nicer.
It is a 100 percent stock 350 (L42)with 28k miles and never touched inside. I would like to keep it that way, but still increase performance. I am looking for suggestions to get the bang for the buck.
What exhaust do you recommend? I would like a little rumble while still being able to have a conversation inside.
I would like to update the stereo but find that it would require modifying the console. No DVD or anything, just would like CD and inputs for mp3 player. Any ideas?
What are thoughts on replacing the air cleaner in order to let the motor breathe better?
Any other ideas where I could wake the motor up a little? Should I dump the Quadrajunk?
Thanks for the input in advance.
Chris
In terms of design capabilities, ability to have good Air/Fuel ratio adjustment throughout the range of use, and the ability to have good economy (when you want it) and good power (when you want it), there is no competitor for the Q-Jet. A Holley may be simpler to work on for performance only, but a good book on Q-Jets will make any work on it relatively easy.
But, if you just want to do what your "buds" say to do, throw it in the trash. Better yet, send it to me!!
As far as "power" is concerned, you will have to do quite a bit to the Chevy SB engine as it was originally producedf in 1980 to make it a real performer. But, it is a SBC engine, and there are a plethera of power mods readily available to do that. I would propose to you, however, that you rebuild the carb (if it was original to that car) and that you recurve the distributor for performance...instead of for lower power/lower warranty costs for GM. You can gain a solid 30 hp for almost FREE with the dizzy recurve, alone. Once you've done that and tested it out, you may find that more money spent is completely unnecessary. If not, the progression of mods should be: dual exhaust system with 2.5" pipes; better cam & compatible heads; better flowing aluminum intake manifold. There is absolutely no reason to change the carb for the purpose of increasing performance!!
As others have said, you've got a good carb. Probably could use a good rebuild though. There's a book by Doug Roe if you're the do-it-yourself type; IIRC its called "Rochester Carburetors". I've got a copy of it around here somewhere.
There is a lot of good info if you do some searching in this forum. There are a lot of overcaffinated people too, so you'll have to wade your way through to the good stuff. Look for papers by forum member "Lars". He has helped a ton of people out with their ignition & fuel delivery questions.
Also keep in mind that there isn't a lot you can do before you start getting into cams, intake, heads, etc. Sure, there are a few thing you can do, but this leads to that in a hurry.
Good luck & have fun!
I have no problem with Holley carburetors. They are very popular with the performance folks and have that reputation. However, they have NEVER been known as an "economical" carb...heck, those that use them are rarely concerned with economy.
GM put Holley carbs on their performance engines for just the reason stated in the previous paragraph: they have the reputation of being THE performance carb. So, they slapped Holleys on their 'top' power engines just so they could have effective marketing. Truth be told, most of those engines (certainly the SB models) would have performed just as well with the Q-Jet; but it didn't have the "rep". And, that would be true of any engine that required a 750cfm [or less] carb. ANY carb can be tuned to perform; and in many dyno tests, it has been shown that the brand of the carb doesn't matter at all on the issue of peak torque/hp obtained by an engine.
Oh, and if I had a car with a performance engine and tri-power with Rochester carbs, I'd be glad to 'meet you in the alley', sometime.
