Hooker side pipe muffler install?
Old May 29, 2012 | 01:43 PM
jayfire's Avatar
jayfire
Default Hooker side pipe muffler install?
I have the Hooker sidepipes installed on my 79. I removed the old muffler inserts and installed some "Sweet Thunders". Now I hear a little rattle on both sides. I think I just dropped them in. Is there a procedure to installing them in the tubes? (Tabs, weld-in, ???) Thanks
Old May 29, 2012 | 01:48 PM
palmbeachvette76's Avatar
palmbeachvette76
On a different set of inserts I was using awhile back I had the same thing and found header wrap would make up for the gap between the insert and the side pipe tube and the rattle was gone.
Old May 29, 2012 | 09:35 PM
U17's Avatar
U17
Once in a while I hear that... until they warm up ....
Old May 30, 2012 | 11:10 AM
jayfire's Avatar
jayfire
I hear mine more when it warms up. I will try the muffler tape. Thanks
Old May 30, 2012 | 10:53 PM
larryg3's Avatar
larryg3
the same happens to mine
Old May 30, 2012 | 11:08 PM
richiev88's Avatar
richiev88
I spot welded each end
To Hooker side pipe muffler install?
