Engine Building
Old May 29, 2012 | 09:03 PM
doublearrow's Avatar
doublearrow
Default Engine Building
Where to learn it? I have a 75 vett and an 87 square body silverado with high mileage tired 350s. I don't have anyone around to learn from, but I want to learn to build engines. Does anyone have some good recommendations as far as books, videos, online ect that are step by step from finding a block to running car? Obviously I won't get the small tips and tricks that an experienced engine builder , but it'd be better than i have now. I can replace parts and do maintenance, but ready to step it up. Any help would be appreciated.
Old May 29, 2012 | 09:13 PM
SIXFOOTER's Avatar
SIXFOOTER
An excellent resource
http://compare.ebay.com/like/1607279...Types&var=sbar
Ahh, and in here are a few guys that know a thing or two
What do you want to acomplish with the engines? Basic Rebuild, make more power, go nuts?
Old May 29, 2012 | 09:37 PM
billla's Avatar
billla
St. Jude Donor '14
I'm betting that if you post in the regional forum, there's someone closer than you think to help out
The book linked is the best one I've seen - and there's a DVD in it. That and a little friendly help will get you through it. Best to learn by doing...the devil is in the details.
Have fun!
Old May 29, 2012 | 09:52 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Default Becoming a student of the subject...
One of the best books you'll find on engine building is The Step-By-Step Guide to Engine Blueprinting: Practical Methods for Racing and Rebuilding by Rich Voegelin. True, you probably won't be doing your own machine work, but IMHO unless you gain a basic understanding of the process you won't know what you don't know.
In addition, you'll want books on the specific type of engine(s) on which you plan on working, and to that end there are a wealth of titles on SBC builds. I'm more of a BBC and BBB guy, so I'll leave the SBC experts to recommend the better ones.
And, if you want to fill out your library, do pick up a copy of Power Secrets by Smokey Yunick. Some of the info is getting dated, but he still knew more than most engine builders will ever learn. Also, suggest How to Build Horsepower, Vols. 1 & 2 by David Vizard.
Also, it will be worth developing a relationship with at least one reputable shop in your area, and IMOE you can learn a lot from them once you know what questions to ask. Highly suggest you not go it alone on your first build without having an experienced builder at least be available for guidance, if not looking over your shoulder. FWIW, I didn't jump right to building engines myself, rather I watched, then assisted, then began performing more and more work. IIRC by the 4th time around I was ready to solo, but it was a while yet before I got around to spec'ing out builds and designing custom cranks, cams and such, so definitely stay on the menu with proven combinations of readily available kit.
It'll take some time and effort to get to the finish line, but there are few rewards as fulfilling as is firing up your first build. Best of luck on your quest.
Old May 30, 2012 | 10:38 AM
GOLF72's Avatar
GOLF72
Despite all the know how you will find in the resources already mentioned, you are going to need the proper tools. Without the tools, you will never get the job done right. You will find yourself right back at the machine shop.
To Engine Building
