fan/shroud clearance
Old May 29, 2012 | 09:29 PM
hughman321's Avatar
hughman321
Navigator
Default fan/shroud clearance
My 69 350/350 runs hot when in traffic on a hot day(85+). The car has been changed around a bit and I am trying to make it original as possible. There is about a 3/4" clearance from the front of the fan and the back of the shroud, so I know some air is slipping past between and not going through the rad. I have been told that the fan should fit inside the shroud, it should extend back and around the fan...i can slip a piece of cardboard between the shroud and the fan. I think there are different water pumps that project further forward and I believe I have the right pump. The AIR is gone, so the belts are not right, there may not be the right stackup on the water pump...I dont know. Should the fan be inside the shroud?
I have pulled the thermostat which didnt really help. I can see flow through the rad with the cap off and engine running, I pulled the rad and had it flushed and flow tested and was told its in great shape....so I'm grasping at straws.
Old May 29, 2012 | 10:26 PM
drwet's Avatar
drwet
There should be about an inch of fan protruding out the back of the shroud for maximum airflow.
Old May 30, 2012 | 02:38 PM
jetjockey's Avatar
jetjockey
Considering the mods you say are on the car, a couple of good photos would get you a lot more help.
Dan
Old May 30, 2012 | 02:59 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you have the metal shroud or the fiberglass? The correct fan is pretty much inside the metal shroud; less so with the fiberglass shroud.
Old May 30, 2012 | 06:24 PM
Alan 71's Avatar
Alan 71
Hi h,
Are you using a fan clutch, and if so, is it working?
Do you have the various foam seals that are used on all four sides of the shroud and on top of the core support? These are important since they force the air to go through the radiator not around it.
There's also a rubber 'flap' about 3"x36" that's stapled to the lower valance in front of the core support... is it there? It forces the air coming up through the 2 breathing holes in the front valance to go through the radiator.
Maybe a combination of things?
Regards,
Alan
Old May 31, 2012 | 10:39 AM
69 Chevy's Avatar
69 Chevy
Originally Posted by Alan 71
There's also a rubber 'flap' about 3"x36" that's stapled to the lower valance in front of the core support... is it there? It forces the air coming up through the 2 breathing holes in the front valance...
My '69 doesn't have that 'flap.' Would you happen to have one of your fabulous pics to illustrate it?
Old May 31, 2012 | 03:16 PM
aussiejohn's Avatar
aussiejohn
Default Good advice above.
hughman,
Years ago I used to sell diesel engines for a living and one thing I learned about them was the correct position of the engine driven cooling fan. Ideally, about two thirds of the fan should be INSIDE the fan shroud, and about one third OUTSIDE. Obviously this applies to all internal combustion engines, regardless of fuel type.
Sounds like you need a spacer that goes between the water pump and the fan, along with longer bolts. A cheap fix, let's know how it works.
Regards from Down Under.
aussiejohn
Old May 31, 2012 | 03:57 PM
JimT's Avatar
JimT
Dead-on AussieJohn! And you really do need the shroud sealed to force the air through, and not around, the radiator - very important!
Old Jun 1, 2012 | 10:20 PM
kkperformance's Avatar
kkperformance
I agree with drwet and aussiejohn, The fan needs to be 1/2 to 2/3 inside the shroud. You may also pour in some of the coolant additives that lower the cooling temp 20-30 degrees. I have seen them work well.
Old Jun 2, 2012 | 03:40 PM
Alan 71's Avatar
Alan 71
Hi 69 C,
It's such a pleasure to finally be able to post a couple pictures for YOU!
You contribute so much, and ask for so little in return!
Regards,
Alan
Flap - right side
Flap - right/center side
Flap - left side
Old Jun 3, 2012 | 08:13 AM
69 Chevy's Avatar
69 Chevy
Thank you Alan for the photos and your commentary on my CF participation.
To fan/shroud clearance
