Oil pressure gauge
Old May 30, 2012 | 03:33 PM
DANNYS8's Avatar
DANNYS8
Default Oil pressure gauge
My 1982 Oil Pressure Gauge Is jumpy.Sometimes it's steady but most of the time it jurks back and forth,not all the way, just between 40 and 60psi any ideas? thanks for any input.
Old May 30, 2012 | 04:01 PM
...Roger...'s Avatar
...Roger...
Of course make sure the connections are tight but most of the time its the sender,exhaust the other possibility's before buying one.
Old May 30, 2012 | 06:23 PM
7T1vette's Avatar
7T1vette
You either have a loose connection somewhere on the sender "signal" wire, or that wire is nearly fatigued through somewhere along its path. The connection at the gauge is unlikely to be the problem; its more likely to be in the engine compartment somewhere.
Old May 30, 2012 | 07:40 PM
DANNYS8's Avatar
DANNYS8
Thanks for pointing me in the right direction.I was thinking the gauge or the pc board behind the gauges.
Old May 30, 2012 | 08:29 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Could be a printed circuit... but probably the sending unit or a connection issue at the sending unit.
If you pull the dash, the picture below will show you which terminal to look for.
Old May 31, 2012 | 12:36 AM
Vette5.5's Avatar
Vette5.5
This isn't something to take lightly. I'd at least temporarely install an undamped mechanical gauge, to see what's really going on. Maybe tee into the existing, for comparison. Possibly a rod bearing going bad, and something you're wanting to know about right away.
Old May 31, 2012 | 05:29 AM
Alwyn678's Avatar
Alwyn678
Old May 31, 2012 | 05:12 PM
0Willcox Corvette
Former Vendor
True and a good idea.. That reminded me of a customer that called here years ago and told us about his car purchase.. Everything worked but the oil pressure gauge. On the way driving down here he found out the gauge was indeed working.
Old Jun 1, 2012 | 05:14 PM
DANNYS8's Avatar
DANNYS8
Thanks Wilcox and everyone for your help and guidence.I am still with no results working on my more serious problem of the code 42 (a 1982 problem)but then it's on to the oil sending switch.I did not think this electronic spark control problem was going to take 2 solid weeks to diagnose.The car runs good but the darn light (check engine) will not go off so this weekend it is back into the wiring.Persistance will pay off.I do have the faith!
Old Jun 1, 2012 | 06:13 PM
7T1vette's Avatar
7T1vette
What is the fault for a 42 code?
Old Jan 22, 2017 | 02:03 PM
violinsib's Avatar
violinsib
Cruising
Default oil pressure gauge and code 42 coninues
I have hooked up a mechanical oil pressure gauge and drove for 2 weeks with perfect oil pressure. Replace the oil pressure sending unit and the oil pressure switch to no avail.
On the code 42, replaced the ignition module on a suggestion from a friend, no help. Then, again followed the flow chart in the shop manual and it tells me there's a short in the ground somewhere....but where do I start looking? Help; car runs good but the mileage is better without the code 42...BTW been running regular gas for years and it runs fine. 26-30 mpg hiway w/o the code 42; 20-26 with the code 42
Old Jan 22, 2017 | 04:15 PM
TimAT's Avatar
TimAT
If you have the GM shop manual, it has the diagrams all laid out showing connectors and grounds. You just have to track the wire thru all of it's connectors. Could be as simple as one has shaken loose. Or a ground got a little crusty.
Old Jan 22, 2017 | 06:04 PM
SwampeastMike's Avatar
SwampeastMike
From what I've read here those mechanical oil pressure gauges contain some oil that slightly dampens the needle movement. If some or all of the oil leaks out the needle can begin to jump very rapidly.
I have the same problem in my '79 especially when coasting. Replaced the sender--to little or no effect. Connections are all good and the PC is new (due to other problems). I have the gauge pack out for some electrical updates and plan to replace the gauge.
Old Jan 22, 2017 | 08:31 PM
Big2Bird's Avatar
Big2Bird
I just changed mine. GM Repop, $50.00. Cured the needle bounce.
Old Jan 24, 2017 | 12:44 PM
violinsib's Avatar
violinsib
Cruising
Digital dash on my 86 pacecar; no needles.
Old Jan 26, 2017 | 09:29 AM
7T1vette's Avatar
7T1vette
Have you removed/cleaned/replaced the connectors on your ECU? Especially check any ground wires going to the ECU. Sometimes those can get a bit corroded or loose, causing problems. Might not help, but its a good thing to do; at least it will eliminate one possible fault. {Maybe eliminate the #42 codes.}
An electrical oil pressure sender is merely a variable resistor between the sender line and 'ground'. If you remove the sender wire and stick a 50 ohm resistor in its place, you can see whether the gauge reading continues to flutter (indicates that the circuit board likely has the problem) or if it becomes stable (indicating that the sending unit is bad). My suspicion is that your problem is the sending unit.
To Oil pressure gauge
