rear 82 spring sagging
Old May 30, 2012 | 04:32 PM
simonfoster84's Avatar
simonfoster84
5th Gear
Default rear 82 spring sagging
hi guys new to the corvette world from sunny england...
i have recently bought a 82 vette the rear is sagging bady to the d/s it has the mono spring... do these still sag? like the steel ones. looking at swapping it out if so. if not it may be other problems if not..
thank you.
Old May 30, 2012 | 05:01 PM
oldalaskaman's Avatar
oldalaskaman
there's some adjustment,
Old May 30, 2012 | 05:43 PM
simonfoster84
5th Gear
hi thanks through the spring bolt at the end of the leaf...
i guess that the only adjusters.. are these springs pretty much unsagable.
Old May 30, 2012 | 06:04 PM
...Roger...'s Avatar
...Roger...
I've never seen a plastic spring sag. I would be very careful ,it might be ready to break,exhaust heat does make them fail.
Old May 30, 2012 | 06:23 PM
oldalaskaman
with the plastic spring, its pretty common on C4's,and usually adjustable with the bolts on the end of the spring. havent had issues with my C3. I actually swapped ends on my C4 spring cause it was sagging bout 1 1/2" low to the drivers side, and it leveled to bout 1/4" high on the drivers side, which when I was sitting in it , leveled it out. Something else to check would be the condition of the rubber bushings. If you have any experience with the mid 70's Triumph Spitfires and others with the transverse spring, all those tricks will work on these also, hope this helps.
btw , check for the proximity to heat as the prev. poster stated.
Old May 30, 2012 | 08:16 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Check it for cracks as well. I just replaced a front spring on a C4 due to sagging. It was cracked in two places. Cheers!
To rear 82 spring sagging
