1974 454 normal temperature?
Old May 31, 2012 | 08:22 PM
scf100's Avatar
scf100
Default 1974 454 normal temperature?
what should be the normal range with this engine say with a/c on in town?
thanks, Stuart
Old May 31, 2012 | 11:20 PM
7T1vette's Avatar
7T1vette
That depends on a number of factors:
What city? What air temperature? What relative humidity? Condition of the radiator? Condition of the shroud seals? Does the thermostatic fan still work?...properly?
In moderate air temp conditions and in city driving with A/C on, you shouldn't see more than 210F, or so. If it goes significantly higher, you could have a bunch of reasons why: bad thermostat; bad thermostatic fan; limed-up radiator; old, ratty coolant; no shroud extension; bad or no radiator shroud seals; defective radiator cap; yadda, yadda
Old Jun 2, 2012 | 08:41 AM
bigvette1's Avatar
bigvette1
This is really a question of what "hot" is. I realize 210 is not overly hot for a BB, but at 210 it is hot and things seem to smell hot, the floors even with liners are hot, the hood is hot and wow -- when you turn it off the heat soak runs up to 240 on a gauge with sensor in the head.
An aluminum radiator car like using a DeWitt radiator will track at 180-190 vs the copper core at 210 or more. So we are back to the question of radiator type and what is acceptable for "hot".
Old Jun 2, 2012 | 09:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by scf100
...what should be the normal range with this engine say with a/c on in town?...
What does the Temp gauge read? Owner's manual also has a blurb about temperatures.
Depending on where you are, you may want to nix the idea of driving in the Fourth of July Parade.
Old Jun 2, 2012 | 10:51 AM
scf100's Avatar
scf100
LOL, temp reading 200-210 in 85 degree weather
sounds like its ok.....but when radiator needs replacing I know what to get....
thanks guys,
To 1974 454 normal temperature?
