engine builders come in
Old Jun 4, 2012 | 08:25 PM
Billysvette's Avatar
Billysvette
Default engine builders come in
Guys ive been haveing a problem for a little while now,im burning oil ,engine runs good,but burning oil especially at full throttle ,at idle it doesnt smoke,only at full throttle. so i took the engine a part because im also putting a 5 speed in.what i found wassmall puddle of oil in the intake runners ,laying on top of closed intake valve.I had loosen up the rockers and it sat for a couple days,i then went out to pull the heads and then i looked inside the intake runner and found the small ,small puddle of oil laying in there on top of valve.My thought is that maybe it came from the valve seals,maybe leaking.I did put high heat silicone on the threads of the rocker studs that are at the intake side,so i dont think it is that.Another one might be that the intake gasket might not be sealed good,i checked that and it seems to be a good seal.These are the only things i can think of that cane do this,what do you think it is? If the rings werent seated then both intake and exhaust valves would be carbined up on the piston side , right? The heads are new afr 210s,could the seals be leaking? Im kinda stumped. Bill
Old Jun 4, 2012 | 08:53 PM
rosros's Avatar
rosros
Do you have valve floating symptons. Hydraulic lifters pulling oil up? Just a stab at your situation.
Old Jun 4, 2012 | 09:27 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Curious, what kind of crankcase ventilation?
Old Jun 4, 2012 | 10:33 PM
njfl's Avatar
njfl
I'd look at your ventilation as well. I'm looking into this for my car. Mine burns oil on heavy acceleration. I currently only have a PCV valve going into the base of the carb. I realized that I have nowhere for air to come in and flow through the crankcase. I have Chevrolet Performance valve covers without baffles, so I suspect that the problem is twofold:
1. oil getting into intake runners through PCV
2. Too much pressure building up under acceleration and nowhere to vent fast enough
I am considering using a catch can to avoid any possibility of spewing oil onto the engine/headers.
Old Jun 4, 2012 | 10:35 PM
Billysvette
No valve floating problems,engine runs good.
Old Jun 4, 2012 | 10:39 PM
Billysvette
Ive tried different ways with one and two pcvs,then 2 vented breathers,no breathers,didnt make any difference.What can cause oil to lay on top of those closed intake valves? I did have one cylinder that was dry.Now i am looking at the valves through the intake runners and the valves are closed.
Old Jun 4, 2012 | 10:44 PM
Billysvette
Am i right about the rings? There would have been alot of carbon in the combustion area over the intake and exhaust valves ,right? I do have total seal rings init also.
Old Jun 5, 2012 | 02:50 AM
oldalaskaman's Avatar
oldalaskaman
I vote, your right on the rings, if it was coming thru the rings your plugs would be wet, and it would blow out the exhaust with out leaving puddles. but then that applies to the rest also,, do your valve covers have baffles? what oil pressure are you running? oil on top of valves , with no baffles, yes. with baffles , valve guides /seals. also could just be a bad pvc, no likely but possible
Old Jun 5, 2012 | 09:29 AM
gkull's Avatar
gkull
I had a fresh motor with brand new AFR 210's Within 1500 miles it started smoking. By 2500 I was embarraced to drive it. AFR oil return sucks and the valve guides are swimming in oil. So I jst changed out the crappy AFR seals with Vintons. Problem cured. Later when I took the heads off I machined a slott outboard of the springs and contoured the drain back areas so the oil returns from the heads.
It takes lots of miles for the rings to ware out
Old Jun 5, 2012 | 09:58 AM
cv67's Avatar
cv67
St. Jude Donor '05
Intake gaskets
Youre not the only one to fix them via rebuilding the motor lol.
Old Jun 5, 2012 | 02:15 PM
Billysvette
I have baffles,,and even tried to modify and change baffles with other baffles,didnt work High volume oil pump,puts out 80 psi cold and about 40 to 50 warm.Ive also tried different pvcs.Im thinking seals ,but these are new afr heads ,usually they have top quality.
Old Jun 5, 2012 | 02:17 PM
Billysvette
Originally Posted by gkull
I had a fresh motor with brand new ZFR 210's Within 1500 miles it started smoking. By 2500 I was embarraced to drive it. AFR oil return sucks and the valve guides are swimming in oil. So I jst changed out the crappy AFR seals with Vintons. Problem cured. Later when I took the heads off I machined a slott outboard of the springs and contoured the drain back areas so the oil returns from the heads.
I guess i will try the vinton seals,and my heads are off the car,do you have any pics of your machining of your heads for the oil to flow better?
Old Jun 5, 2012 | 02:22 PM
Billysvette
Intake gaskets
Yea i thought about them too,but i could not see anywhere where the gaskets were leaking.Looked to be a good seal all the way around,but i am going to try and different intake gasket this time around.I used felpro 1206.
Old Jun 5, 2012 | 02:53 PM
cv67's Avatar
cv67
St. Jude Donor '05
Could very well be something else..look on the backside (head) of the intake gasket towards the bottom thats typically where Ive found mine.
Old Jun 8, 2012 | 05:20 PM
Billysvette
Guys i found out that afr heads come with viton valve seals,so now im puzzled again.i dont think its them.Now maybe its the rocker studs leakingor intake gasket .i did use high temp silicone on the rocker studs,maybe not enough,i dont know.The intake gasket,if it was leaking would leave oil on top of valves wouldnt it? does anybody know of a good intake gasket that really seals good?
Old Jun 8, 2012 | 10:10 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
You have a blower right? My guess is your forcing pressure past the rings, crankcase pressure is building and that pressure is forcing oil past your valve seals, intake gasket or pressurizing the PCV causing mist to enter the intake. I would do a leakdown test on it.
Old Jun 8, 2012 | 10:13 PM
63mako's Avatar
63mako
http://www.summitracing.com/parts/MRG-5822/
To engine builders come in
Old Jun 8, 2012 | 11:10 PM
TheSkunkWorks
Ding, ding, ding!
Might should check crankcase pressures too while you're at it.
Old Jun 9, 2012 | 02:48 AM
Ralphbf's Avatar
Ralphbf
Do you have a high volume oil pump?
Filling the valve covers with oil only at high RPM's
I've seen oil pans emptied and valve covers full before.
It gets UGLY fast.
Ralph
Old Jun 9, 2012 | 10:38 AM
Billysvette
Mako its all apart right now,im going to redo the engine and im putting in a 5 speed trans.The only clues i have is that theres oil laying on top of the intake valves.
