engine builders come in
Old Jun 9, 2012 | 10:40 AM
Billysvette's Avatar
Billysvette
Originally Posted by 63mako
You like them better then felpros?
Old Jun 9, 2012 | 10:43 AM
Billysvette
Originally Posted by TheSkunkWorks
Ding, ding, ding!
Might should check crankcase pressures too while you're at it.
Its all apart now.I am running total seal rings,you would think that would help with pressure.i guess i should have got the max seal total seal rings
Old Jun 9, 2012 | 10:48 AM
Billysvette
Originally Posted by Ralphbf
Do you have a high volume oil pump?
Filling the valve covers with oil only at high RPM's
I've seen oil pans emptied and valve covers full before.
It gets UGLY fast.
Ralph
Yes i have a high volume pump,im thinking also of putting a regular oil pump in while the engine is apart. This is the only time ive ever been stumped on a engine problem.
Old Jun 9, 2012 | 11:00 AM
Billysvette
Ok guys what all do you think i need to buy to solve this problem.Give me a list and i will buy it.In my mind i was going to do something anyway,even if it has to do with a total rebuild.Buy the way the engine is not that old,everything was new and built about a year or so ago.
Old Jun 9, 2012 | 01:47 PM
Billysvette
Each one of you please give a list please,i want this mistifying problem solved.
Old Jun 9, 2012 | 02:45 PM
oldalaskaman's Avatar
oldalaskaman
you dont need a list, you need to disassemble and reassemble ...carefully
Old Jun 9, 2012 | 03:03 PM
Ralphbf's Avatar
Ralphbf
I've got twenty dollars that says the high volume pump is the problem.
Valve covers are being filled to over the top of the valve stems.
Even the worlds best valve stem seals were not designed for this.
They need to let some oil pass through to oil the stem.
I never run high volume pumps.
I use the Mr. Gasket high pressure spring in a stock pump.
I understand you can simply use a 1/4" spacer to do the same thing, but never tried it.
Ralph
Old Jun 9, 2012 | 03:13 PM
Billysvette
Ralph
Thanks Ralph ,im going to go with a lower pressure oil pump,i was thinking a 10% higher then stock pressure pump from mellin. Bill
Old Jun 9, 2012 | 03:17 PM
Billysvette
You maybe be right,i think to be safe i will put some different pieces in engine,like oil pump , better sealing intake gaskets,Maybe a set of max seal total seal rings.Bill
Old Jun 9, 2012 | 04:30 PM
OMF's Avatar
OMF
If your engine is apart already I'd put a new set of valve seals on anyhow.....maybe one got nicked during the last install. How about opening up the oil drain back holes slightly in the heads, and doing a little touch up with a die grinder to promote oil drain back into the pan.
I know squat about blowers, but is there any chance the oil is coming from it...oil slipping by the seals....do they have an oil bath for the bearings???
Old Jun 9, 2012 | 04:33 PM
oldalaskaman
excellent
Old Jun 9, 2012 | 05:20 PM
Billysvette
Blower is self contained ,doesnt use motor oil at all.I think i might just buy a set of new viton seals since its apart.
Old Jun 9, 2012 | 05:29 PM
  #33
rosros's Avatar
rosros
I visited my engine builder and he thought either too high oil pump or aftermarket valve covers with poorly instituted oil separater.
Old Jun 9, 2012 | 08:16 PM
  #34
Billysvette
Thank you,i have billet specialties valve covers,they are pretty good pieces,dont think its them.But the oil pump ,you might have hit something there.Im going to change the HV pump for a lower pressure pump.Hope thats it.
Old Jun 10, 2012 | 12:19 AM
  #35
63mako's Avatar
63mako
St. Jude Donor '08-'09
yep! Did you do a leakdown test before disassembly?
Old Jun 10, 2012 | 12:21 AM
  #36
Ralphbf's Avatar
Ralphbf
That would be a standard volume high pressure pump.
They sell them that way now.
Ralph
Old Jun 10, 2012 | 12:43 AM
  #37
Billysvette
No i didnt,pulled motor with trans to do a trans swope,5 speed. so i desided to fix engine while im at it.
