Crazy horn
Old Jun 5, 2012 | 02:23 PM
cyclops1032's Avatar
cyclops1032
Default Crazy horn
I bought my 81 Corvette last July knowing it wasn't perfect. The horn and alarm never has worked since I have had it. The previous owner had a horn button bolted to the side of the console..lol..but the wires were not hooked up. A month ago I removed all of the interior so I could change the color. The wires going to the t-top alarm switches were cut and taped up and the hood switch is completely gone. I figured the alarm, had been disconnected. I removed the steering wheel to redye it and also to check out the horn. I got the interior back in and the horn still didn't work. I got in the car last night to move it around to the back yard under the carport. I started it and turned the headlights on and the horns started pulsating! I pulled the wire off the horns and moved the car around to the back yard. I looked in the shop manual but really can't find why this all of the sudden happened. Like I said, this car isn't perfect. The wiring has been hacked up and I have straightened alot of it up. It's not the original engine and the computer system has been removed. What do I need to do to disconnect the alarm permenantly and get the horn working? Also, why would this just all of the sudden happen?
Old Jun 5, 2012 | 04:13 PM
KevinK's Avatar
KevinK
When I got my car, the horn beeped when I made hard left hand turns, lol. Is the fuse for the alarm seperate from the horn? If so, just pull the fuse for the alarm until you fix the issue.
Old Jun 5, 2012 | 06:23 PM
cyclops1032
I thought I would try that and see what works and don't work..lol.
To Crazy horn
