water pump possibilities?
Old Jun 6, 2012 | 09:18 AM
ltblue79's Avatar
ltblue79
Default water pump possibilities?
So Im finishing up my motor and I need a new water pump. I dont need anything fancy or super expensive. Just a decent pump that works well. Summit has many to choose from but I was thinking this would possibly work?
http://www.summitracing.com/parts/SUM-312534/
Im also going to put a new fan clutch on since its all apart. Would this be fine?
http://www.summitracing.com/parts/HDA-2741/
If anyone knows of a better for same amount of money or one thats cheaper and the same quality please let me know. Thanks!
Old Jun 6, 2012 | 09:20 AM
Mike Ward's Avatar
Mike Ward
There's nothing wrong with using the stock GM pump and clutch.
Old Jun 6, 2012 | 09:21 AM
ltblue79's Avatar
ltblue79
Originally Posted by Mike Ward
There's noting wrong with using the stock GM pump and clutch.
both are shot that were on the car so they need to be replaced
Old Jun 6, 2012 | 09:26 AM
Roco71's Avatar
Roco71
Some aftermarket pumps have issues with pulley alignment.
Old Jun 6, 2012 | 09:47 AM
dmrodco's Avatar
dmrodco
yes this is true the corvette doesnt use the Llong or the short pump they use a corvette specific lenght that is in between long and short. buy one for use on a corvette or it will not line up ! ask me how i know. i have a few longs and shorts laying around the shop
Old Jun 6, 2012 | 10:02 AM
jb78L-82's Avatar
jb78L-82
I have used the Stewart water pump now for a few years on my 78 L-82 and have been very satisfied: I use the aluminum stage 2 pump and the car has never run cooler-$175. Stage 1 cast iron is $90. For the little extra money, I would highly recommend their pumps and they sell a corvette specific one-fits perfectly.
http://www.stewartcomponents.net/Mer...y_Code=ChevyS2
Old Jun 6, 2012 | 10:07 AM
Solid LT1's Avatar
Solid LT1
Edelbrock water pump user here, best pump for the $$
Old Jun 6, 2012 | 11:13 AM
scottyp99's Avatar
scottyp99
If you have access to a press, this is an option.
http://www.corvettemagazine.com/engi...p-rebuild.html
Keep the shiny side up!
Scott
Old Jun 6, 2012 | 06:19 PM
sfrank2886's Avatar
sfrank2886
I second that motion. Have run them for a long time in polished form. Look good as well. MTC
Old Jun 6, 2012 | 07:22 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I just installed this pump and used some pulley shims to align the pulleys without a problem. I also installed the Hayden 2741 fan clutch again without any issues. Recommend these two items. Also, you need a thermostat that has holes drilled into the top if use the Stewart Stage 2 pump because it doesn't have a bypass function. It's not a big deal.
Old Jun 6, 2012 | 08:58 PM
billcarson's Avatar
billcarson
i agree to try to rebuild the pump if possible.they seem very heavy duty and mine needed only cleaning and gaskets.luckily because i could not find the rebuilding parts for my year pump.only the early years were available.good luck.
Old Jun 6, 2012 | 09:14 PM
3JsVette's Avatar
3JsVette
GM or Stewart. You won't go wrong with either one.
IMCO I would not skimp on cooling system components especially for a Corvette.
Good luck with what ever you choose.
Old Jun 7, 2012 | 09:13 PM
oldboat's Avatar
oldboat
stewart for sure. fits right in and keeps the engine cooler.
Old Jun 8, 2012 | 08:11 PM
80stroker383's Avatar
80stroker383
Used a stock replacement from pep boys on my 383 stroker, no issue on $33.99
http://www.pepboys.com/product/detai...g/water_pumps/
Old Jun 9, 2012 | 09:32 AM
Xterrable's Avatar
Xterrable
I vote Stewart as well. I have the aluminum stage II as well and love it!
Old Jun 9, 2012 | 10:10 AM
Mike Ward's Avatar
Mike Ward
There you go...........
Old Jun 9, 2012 | 10:28 AM
mds3013's Avatar
mds3013
The new GM/Delcos are some of the ugliest pumps I have ever seen. I went with a new NAPA pump. I did a little clean up on the hose neck area and outside. OK so far. mike...
Old Jun 9, 2012 | 07:00 PM
Street Rat's Avatar
Street Rat
There are plenty of choices. Stewart is the way to go imo.
To water pump possibilities?
