Plug wire recommendation
Old May 23, 2002 | 11:19 PM
hudman's Avatar
hudman
Default Plug wire recommendation
I have a 427 that presently has some standard plug wires (non right angle) that will not fit will under the distributor shield cover very well. You can install the cover, it just does not fit well without really pinching the wires.
What do you guys recommend to use that have the right angles at the distributor end that I can use so that I can reinstall my cover and not worry about crunching the wires?
I am looking for a high performance wire at a reasonable price, and preferably something that I can just order from Summit or Jegs.
Old May 23, 2002 | 11:32 PM
Schmucker's Avatar
Schmucker
Default Re: Plug wire recommendation (hudman)
Can't you just raise the cover a 1/4 with some nuts (note, I have no idea how the covers go on as I have never touched one)
Old May 23, 2002 | 11:39 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I have Accel 8.8 mm 300 wires with right angles at the cap. They are a reasonably priced high quality wire, and are black.
Check http://www.summitracing.com/ or http://www.jegs.com/
Old May 24, 2002 | 12:36 AM
JB's Avatar
JB
St. Jude Contributor
While we're on the topic, I've been looking at braided wires like the ones that were originally on my 427. Several catalog vendors carry stainless braided wires for about $59 and "correct" braided wires for about $100. Anyone know what the difference is appearance wise?
JB
Old May 24, 2002 | 01:14 AM
trw's Avatar
trw
The aftermarket braided wires do not have the ground wires that original had.
I think the aftermarket are better quality that stock 30 year old design, but it's what look you want.
Terry
To Plug wire recommendation
