You seem real confident you got zero lash then adjusted the valves right so, yes, back them off 1/2 turn is fine.
I will try this next and see how it acts. If I still have the issue I will redo the whole procedure.
The idle did seem better today just going between 600 and 700 RPM, and not the larger jump like last night, so maybe re-torquing the bolts helped some?
I was thinking......since you had the manifold off and on 3 times now, grab that dist, and turn it an inch ccw to advance timing. jump in and go around the block. you'll go ( dang, thats better ). Then turn it another inch and cruse around. Now you have a bunch of timing and the low speed circut loves it and will need adjustment to slow it down some. course now it wants to ping a bit....so you'll have to compromise on the dist position . If nothing else, you'll have to limit total advance with springs or weights. p.s. tight valve adj is like having a vacuum leak....so follow these guys advice alot. Cams change the game. Fun!
I backed all of them off 1/2 turn and the idle seems better and the chugging is almost gone now. Could the valves still be to tight, or should I check the timing again first? Does the valve adjustment effect timing?
The valves could be too tight. Adjusting the valves does not affect timing.
its kinda messy, but you can with the valve covers off, start the engine and adjust the valves with it running. You start at the front, on either side, back them off, one at a time till they start to clatter, snug them down one at a time, till they stop clattering, and go 1/2 turn past that. Then go to the next one. used to be the cold lash adjustment was only to get it running. hope this helps. btw , they used to make two piece valve covers for this method and some folks would take an old set and cut the tops off.
If backing them off helped you need to readjust them all again. I always jiggle them up and down instead of spinning them to determine zero lash. You can tell just when you hit zero this way. This will not affect timing. Keep plugging away, you will get it.
Okay, I will adjust them all again. I did the up and down to get what I thought was zero lash. The first time around I did 1 full turn after I had no movement up or down on the pushrod.
I'm going to do these again tomorrow. I am trying to decide if to adjust running or not. Since everything is already tight, how would I adjust them with the motor off? I just want to get this right tomorrow.
take them all loose but not off , leave it sit over night, adjust them as if you had never done them the first time, that way you're not over or under adjusting them
Well I re-adjusted the valves and replaced the intake gasket again and guess what? Exactly the same! So asked asked a guy I used to work for in high school (auto garage). He asked me about 5 questions and told me the carb was to lean. I went up 2 stages richer on the rods and the car runs a lot lot better. It still needs a little more fine tuning, but it's nice to know that the valves and intake where right.
After the cam swap I took it for a run and when I got back I had a lot of oil on the back of the motor and thought it was coming from the distributor because the clamp was not in the right spot. Tried that with no luck and then replaced the gasket with the same result. So, pulled the intake and replaced the gasket again. Now, no more oil leak, but now I have the other issue stated above. I have done the intake on my car two other times with no issues.
This is why everyone didn't put the carb running lean on the list. It sounds like the issue started after the intake was pulled for the oil leak. Sounds like your new cam wants more fuel than the old one. Hope you get it ironed out.
It was a strange couple of days with this, but I'm getting there. I have richend it up 16% according to the chart that came with my carb.
My buddy also told me a good way to know if the intake has a leak is to hold it steady at like 2100 rpm. If it's smooth like mine was, it's not the intake.
Reason: More info
When you get it sorted post up how the new cam is working out for your combination. Real world feedback is always helpful for others in the same situation.
Changing the cam will very likely require a change in the calibration of the carburetor. You can get an air/fuel ratio gauge and see what the carb is sending to the engine in real time; it can be an invaluable tuning aid.
If the engine will run, and you have hydraulic lifters, you can adjust the valves with the engine idling. Remove one valve cover, and position some cardboard so the oil won't fly everywhere. Start the engine, and carefully loosen the first rocker arm nut to where the valve just stops clattering. This is zero lash. Do the other seven valves on that side. Shut off the engine, and tighten each nut to your preferred preload setting- usually 1/4 or 1/2 or 3/4 turn. (Some of the old hands say that the smaller preloads can increase the RPM at which valve float occurs. But don't bet your engine on it. Obey the redline that the factory or your engine builder specifies.) Button it up and do the same thing to the other side.
Okay guys, I still have a low rpm stumble or hesitation. I have tried several different metering rods and riching up the carb has helped. I also adjusted the secondaries on my AVS carb to kick in a little later. I have replaced the vacuum lines for the brake booster and the PCV valve. I would like to get a kit and replace them all, but I have been replacing the ones that I can easily get. I have had my hood open more than it's been closed the last few weeks and I still can't totally eliminate my issue. I have the vacuum advance hooked up to the passanger side of the carb. Would trying it on the other side do anything or not?
