dashlights
Old Jun 11, 2012 | 08:44 AM
80L82's Avatar
80L82
Default dashlights
Hey guys....the dashlights are out in my '80 vette as well as the dome light. The drivers side power window is not working either, but I'm not sure they're related. A mechanic told me it was the headlight switch so I changed it. Still no lights. I'm having a vette guy look at it on friday, but where would you suggest to look next?
Thanks!
Old Jun 11, 2012 | 08:47 AM
...Roger...'s Avatar
...Roger...
For the dash lights,make sure the INST light fuse has power on both sides when the HL switch is pulled out.
Domelight is on the Courtesy light circuit.
Old Jun 11, 2012 | 09:11 AM
Alwyn678's Avatar
Alwyn678
I just replaced all of mine and Wow does it make a difference in the look and readability. It is not That hard to do and it really improves the readability and accuracy of the gauges
Old Jun 11, 2012 | 09:31 AM
80L82's Avatar
80L82
All of your fuses or all of the dash light bulbs?
Old Jun 18, 2012 | 11:37 AM
80L82's Avatar
80L82
Just spoke to my mechanic and they think the dashlight problem is the printed circuit board? Does this sound like a possibility?
Old Jun 18, 2012 | 12:36 PM
Street Rat's Avatar
Street Rat
My dash lights don't get very bright. They went out once and it was the fuse. I replaced the printed circuit board because it had a wire soldered on the back of it. My lights are still dim. So I guess I need a headlight switch. I'd check your dash ground or printed circuit board for your problem.
Old Jun 18, 2012 | 01:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yes, but there are other things to check first. Fuses - instrument panel and courtesy. Dash harness ground.
Old Jun 18, 2012 | 01:26 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
Make sure the wiring harness plug that goes in the dash is well pushed in, a light switch may do it also , or a fuse . or printed circuit
Old Jul 5, 2012 | 11:17 PM
80L82's Avatar
80L82
Ok....so far I've replaced the headlight switch and speedo/tach circuit board. I have interior lights and the directional indicators work. Still no dash lights. Any other thoughts?
Old Jul 5, 2012 | 11:36 PM
...Roger...
Does the INST fuse have power on both sides of the fuse ?
Old Jul 6, 2012 | 12:15 AM
dgheinen's Avatar
dgheinen
Can someone provide a picture of this wiring harness plug that goes into the dash?
Mine work-sometimes. My low fuel works every so often, but doesn't stay on when fuel is low. It'll go out after a minute or so, and that's the only one that works above the gauges.
Old Jul 6, 2012 | 08:36 AM
80L82's Avatar
80L82
My mechanic is doing the work. I'll check with him. I would hope that they checked it though....I was just wondering if there was anything I could help them with. They're kind of stumped.
Old Jul 10, 2012 | 08:13 AM
80L82's Avatar
80L82
Update: After much head scratching and hair pulling out they're fixed. Turns out the car at one point had power door locks that were removed. Apparently the wires were just cut inside the doors and were shorting out the dashlights.
Thanks for all the suggestions!
Old Jul 10, 2012 | 11:05 AM
...Roger...
OMG , How much did they get you for ? That explanation is very questionable.
Are you pulling our legs ?
Old Jul 10, 2012 | 02:26 PM
80L82's Avatar
80L82
Nope. That's what they said. Very inexpensive too....
But it may have been a process of elimination. I changed the headlight switch and they put in the speedo/tach circuitboard.
To dashlights
