Tire Size
Old May 24, 2002 | 03:36 PM
Kenwood_71's Avatar
Kenwood_71
3rd Gear
Default Tire Size
Does anyone have a problem with 245/60/15 tires rubbing on the inside fender wells. I'm thinking about going down to 235/60/15, what do you think?
Old May 24, 2002 | 04:15 PM
shotgun_000's Avatar
shotgun_000
Default Re: Tire Size (Kenwood_71)
First, I would make sure your front suspension is not worn out. I had the stock size tires, P225 70R15, that never rubbed. I recently upgraded to a set of Firestone Firehawks SS20, size P255 60R15. On the driver side, the front tire rubbed with a hard left turn. I know that some C3 vettes came with this size from the factory, so I figured the wider tires were not the problem. Turns out that my front suspension was worn, and had enough play in it to cause it to rub. P255 60R15 is as wide as you can go in the front, and even then it is very tight. So, any play can cause rubbing.
So, if you have a smaller size, P245 60R15, that is rubbing, check the suspension first. I think you should keep as wide a tire as possible, especially if you plan to add more power later.
Old May 24, 2002 | 04:56 PM
Todbo's Avatar
Todbo
Default Re: Tire Size (shotgun_000)
kenwood71 , just read an old mag article about what size tires will fit on c3 , they were using a 71 in the story. I'll relook at the article and send you the info - by tuesday. Todd
Old May 24, 2002 | 07:20 PM
fontking1a's Avatar
fontking1a
I'm using 235s up front and 255s in the rear and have been for years. No rubs, no scrapes and the what you see in the picture is the look you get with that size. The tires are BFG Radial T/As in a 15" wheel size 60 series mounted on Western Wheels.
Old May 24, 2002 | 10:06 PM
79er's Avatar
79er
Like Shotgun said some vettes like my 79 came from the factory with 255/60/15 on all fours. I never had any problems with rubbing with them even at autocross events. I am now running 255/50/17 and they also have no rubbing issues. My 2 cents.
Old May 25, 2002 | 02:24 AM
LT1driver's Avatar
LT1driver
255/60/15 goodyears here and no problems what so ever. :cheers:
Old May 29, 2002 | 05:00 PM
Todbo's Avatar
Todbo
Default Re: Tire Size (LT1driver)
kenwood 71, it was vette july 2000, pg 74. "A 255/60 -15 tire mounted on a stock wheel , will fit on the front of a 68 -82 Corvette w/o hitting" on the rear "255 cross section tires will usually fit with no problems. The extra width of the 275 cross section is just enough to put the welfare and structural integrity of th tire's inside sidewall at risk". The article goes on to show how to move the parking brake mounting bracket. October of this year vette mag is promising part two of this experiment using non stock wheel sizes (17" , 18")
Old May 29, 2002 | 05:18 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
255/50/15 on my 68 and 80 and no rubbing. (However - my Vettes are not stock)
:cheers:
Olivier
Old May 29, 2002 | 05:44 PM
Tomi72's Avatar
Tomi72
There are probably some small variations from car to car. I have 245/60-15 all around and the fronts very very slightly rub the frame at full lock.
rgds Tomi
Old May 29, 2002 | 06:01 PM
jerryp58's Avatar
jerryp58
My suspension is basically stock and much of it is original (I've only replaced the shocks and the rear spring & strut rods).
I've had 245/60-15s for about 7 years now with no problems at all.
Old May 29, 2002 | 06:02 PM
Gator81's Avatar
Gator81
Exactly what Shotgun said. I was getting a minor rub on the d.side at full-lock left turn, where the sidewall was polishing up a bolt head that protrudes slightly from the frame behind the suspension. It wasn't hurting the tire, and I never worried about it. Was running 255/60-15 BFG T/A's. Also had old, tired springs. Now that I've replaced the springs and shocks, no more rubbing; so that bolt head is starting to rust... :rolleyes: Just recently changed tires, to Pirelli Scorpion Zero, same 255/60-15 size. No rubbing. :seeya
Old May 29, 2002 | 06:09 PM
72rdstr's Avatar
72rdstr
225/60/r15s rubbing on Both sides. But, my suspension is shot. Have a new one in the box and will be rebuilding soon.
To Tire Size
