Certification Decal on Drivers Door
Old Jun 13, 2012 | 07:40 PM
1owner72bb's Avatar
1owner72bb
Cruising
Default Certification Decal on Drivers Door
I lost my numbers
Does anyone know of a data base, for lack of better discription, of the gross, front and rear weights for a 1972...
Coupe
Big block
MT
With AC
with power windows
With radio
No power brakes
no power steering
no deluxe wheel trim
Old Jun 13, 2012 | 11:43 PM
mark6669's Avatar
mark6669
I have a name and address of someone who sells the door decals maybe they can help.
Mark
Old Jun 14, 2012 | 08:16 AM
oldsarge's Avatar
oldsarge
This will not be exact, but it will be close, I think.
Old Jun 14, 2012 | 08:37 AM
1owner72bb's Avatar
1owner72bb
Cruising
This is VERY close to what I have backed into by adding and subtracting the GM AMA weights per options.
How does this car differ from the options I listed?
HUgh
Old Jun 14, 2012 | 11:53 AM
mark6669's Avatar
mark6669
When was your car made heres the tag from my 12/71 72 coupe with original paint no weights on it. Date a little hard to read it's 12-71
Mark
Old Jun 14, 2012 | 06:53 PM
oldsarge's Avatar
oldsarge
The tag I posted is not mine. It is one that someone posted for me to help me with my 73 BB. I think it was a almost fully optioned 73 BB car, but not 100% sure. The numbers would be close, other than the build dates of course.
Old Jun 15, 2012 | 08:21 AM
1owner72bb's Avatar
1owner72bb
Cruising
Mark
My car was built May 30 1972. They changed to add the weights by then. Hugh
Old Jun 15, 2012 | 08:23 AM
1owner72bb's Avatar
1owner72bb
Cruising
Thanks for this. I have collected several others from here and there and built an excel sheet to add an subtract weights depending on options. I have a copy of the old GM paperwork that identifies the weight and Frt Rear split by option.
Thanks again, will see what else pops up
Hugh
Old Jun 15, 2012 | 12:42 PM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
Originally Posted by 1owner72bb
I lost my numbers
Coupe
Big block
MT
With AC
with power windows
With radio
No power brakes
no power steering
my July/72 build small block coupe with m/t, no a/c, pw, pb, ps and stereo radio. If you think it would help I will post a pic of mine, but it sounds pretty far off from yours
Regards
Roy
Old Jun 15, 2012 | 12:59 PM
1owner72bb's Avatar
1owner72bb
Cruising
Regards
Roy
Hi Roy, let me have your numbers and I will back options in and out.
Does your have deluxe wheel covers? They are 18 gross 9 frt and 9 rear if you do.
Regards
Hugh
Old Jun 15, 2012 | 03:19 PM
rvazquez's Avatar
rvazquez
Regards
Hugh
Hugh, no deluxe wheelcovers
mine is a LT-1
hope it helps some
Roy
To Certification Decal on Drivers Door
