Help with crate engine for 81
Old Jun 15, 2012 | 08:11 AM
pokerjoker's Avatar
pokerjoker
2nd Gear
Default Help with crate engine for 81
Hello guys,
I have a 81 model that the engine needs replacing. I've been working on this car for a little over 3 years now and I have the ECM working great, with good/no codes and no check engine light. The engine however is shot and now I need to replace it.
Looking at GM Performance 260hp and also the 290hp crate engines. I'm leaning toward the 290hp, Summit says the old carb, dist., intake and ECM will work fine with this engine.
Jegs however says I may have issues with the ECM because of the cam and they suggest the 260hp engine.
Here's what I know about the cams: 290hp engine: Lift: .450"intake, .460" exhaust - Duration: 222* intake, 222* exhaust @ .050" tappet lift - Centerline: 114* ATDC intake, 114* BTDC exhaust
On the 260hp engine this is what I know: .383"/.401" and 112* lobe separation.
Question is do any of you run a modified cam with the original ECM? Any problems? Can the carb be adjusted to fix any idle problems, maybe a new prom chip for the computer?
Any help will be greatly appreciated.
Jeff
Old Jun 15, 2012 | 09:35 AM
damoroso's Avatar
damoroso
I ran the ECM and associated sensors and carb when I swapped a big block into my car. It work fine with the exception of idle. I had to richen up the idle circuit to the point the O2 sensor didn't like it based on the parameters programed into the ECM via the prom. I ended up pulling the ECM, and the electronics out of the carb. I think you're going to see the check engine light on a regular basis, but it'll clear after you get off idle. A different prom won't help, all those do is change the distributor advance curve a bit. And that's another area where you might run into issues. The ECM controls the distributor too, and it's fairly restrictive...
Old Jun 15, 2012 | 11:02 AM
scottyp99's Avatar
scottyp99
Originally Posted by pokerjoker
Hello guys,
Jeff
OK, this doesn't have anything to do with your question, but it is kind of a pet peeve of mine, and I'm going to share it. The only difference between GM Performance's 260 hp engine, and the 290 hp engine is the camshaft. But they charge an extra 500 bucks for it, so you are basically paying 500 bucks for a 40-year-old-design, flat-tappet camshaft. Get the 260 hp version, and I'm sure you can find a better cam for less than 500 bucks. Hell, you could upgrade to a retro-roller for that much money.
Keep the shiny side up!
Scott
Old Jun 15, 2012 | 01:46 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Can the ECM on an '81 be eliminated altogether? Then buy whatever engine you choose.
Old Jun 15, 2012 | 02:15 PM
qwank's Avatar
qwank
Get the 260 HP and like already said, convert it to a roller cam. You could probably even find a roller cam that will make good power and idle well enough to keep you ECM happy.
Anyone try a ZZ4 in an '81 with stock ECM?
Old Jun 15, 2012 | 02:44 PM
billla's Avatar
billla
St. Jude Donor '14
How do you know it's "shot"?
Buy the longblock and swap in the stock cam for your 'Vette...or as noted, get a better cam and spend the $$$ to have the ECM tuned.
Old Jun 15, 2012 | 03:21 PM
damoroso's Avatar
damoroso
These ECM's can't be "tuned", and a smooth idle won't make it happy either. If you want to keep the ECM, I suggest you learn a bit more about it. It will take some mods like a cam and headers, but you have to work the carb and use a differnt PROM to take advantage of the different advance curve. Like I said in an earlier post, teh ECM controls the distributor too, it also controls the lock up of your trans if you have an automatic.
The best place to learn about this system is the factory service manual. It has a whole section on it and the carb too.
Old Jun 15, 2012 | 04:08 PM
Richard Cooper's Avatar
Richard Cooper
resdoggie,
Yes, the ECM can be eliminated. I bought a crate engine from Paceperformance. Its a 300HP/350, I eliminated the computer, got a new carb and distributor and am VERY happy with the set up. I used the opriginal intake and everything worked fine.
billla's Avatar
billla
St. Jude Donor '14
use a differnt PROM
The new EPROM was what I was referring to when I mentioned "tuning"
Old Jun 15, 2012 | 04:21 PM
jim-81's Avatar
jim-81
I have the older GM 290 or 330 (don't know) crate engine in mine, replaced by PO in 2005, and am not using the ECM. It runs great. You don't need it. Toss all the smog stuff while you're at it.
Old Jun 15, 2012 | 07:05 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Originally Posted by Richard Cooper
resdoggie,
That would be the route I'd take if I had an ECM.
Old Jun 15, 2012 | 11:24 PM
pokerjoker's Avatar
pokerjoker
2nd Gear
Default Many Thanks!
Thanks for all the replies! Certainly a lot to think about. I'm convinced I want more hp than the original engine had. So, if I go with the 350/290 and I can't get the carb, dist., and ECM working I can change them and lose the ECM (as a last resort).
I think I'll try to make it work with them and see what happens.
Bill...I believe the original l81 is shot because I've developed a real bad "knock", I'm losing oil pressure (down to 0) when sitting still or coasting into a turn and when I changed the oil last Friday, I've got a lot of metal shavings showing up in the filter...took it to the shop to have them listen to the "knock" and between that and the metal in the filter they think its time for a rebuild.
Old Jun 16, 2012 | 12:05 AM
uxojerry's Avatar
uxojerry
Pace is a good place to compare engines. They have some really good prices. You may want to consider buying more horsepower and going EFI.
To Help with crate engine for 81
