Old School Motor with EFI or LS
Old Jun 16, 2012 | 03:03 AM
uxojerry's Avatar
uxojerry
Default Old School Motor with EFI or LS
Im slowly wrapping up my C2 Coupe and plan on building a custom C3. The next car will have a TCI 6X transmission, which is a 6sp auto for the wife. The transmission is good to 800hp, not that I want 800.
My choices for engine are an all aluminum BBC with EFI good for about 650hp or an LS motor with relatively equal performance specs. Cost is about equal.
BBC downside is mpg. LS downside is having a completely computer controlled motor.
Opinions are appreciated.
Old Jun 16, 2012 | 03:07 AM
Shark Racer's Avatar
Shark Racer
You'll already have to have a ton of computer controls for the transmission... I'd be going EFI on either motor you setup. The BBC is a lot more front weight too, not to mention harder to service. Much more power potential out of a BBC, but it's really hard to beat the LS.
What are the goals for the car aside from power numbers?
Old Jun 16, 2012 | 03:51 AM
uxojerry's Avatar
uxojerry
The TCI transmission has a stand alone mini computer, much like the EFI. The car will be more of a touring car and occasional track duty for fun only. I dont have the weight specs an the all aluminum BBC.
My concern with an LS motor is the perception of it 10yrs from now. My C2 has a Dart SBC 427 with an 8 stack EFI. For the C3 I want a different motor but am looking for the car to hold some value. Will the LS motor be viewed as obsolete when the Gen 5 motors arrive?
The rest of the car will be equipped similar to my C2. Custom Chassis and suspension, with a little more luxury in the passenger compartment.
Old Jun 16, 2012 | 08:14 AM
Garys 68's Avatar
Garys 68
I've done 2 LS swaps, so you know where this is going.
A BBC with TBI is not much better than a carb for milage or performance. If you go that route and you're planning on a stand alone trans computer, just go old school carb.
A better choice might be an LS3/6 speed takeout from a camaro. The stand alone trans computer is stupid expensive, let the GM ecu handle the motor and trans.
As for being outdated in a few years. I dont think it will be as bad as an LT1. A lot of that was bandaids put on the first gen SBC. And I'm not sure the next gen (DFI) will be aimed as much toward performance vs fuel economy.
Old Jun 16, 2012 | 08:38 AM
uxojerry's Avatar
uxojerry
Sounds like pretty good advice. I may need to overcome my aversion to LS motors.
Old Jun 16, 2012 | 09:15 AM
Garys 68's Avatar
Garys 68
btw, the 6L80 is HUGE!. Tunnel mods will almost certainly be necessary.
Old Jun 16, 2012 | 09:24 AM
zwede's Avatar
zwede
If you're looking for visual appeal you need the BBC. Maybe a short stack injection, or single 4 bbl throttle body hooked to an L88 air chamber.
Old Jun 16, 2012 | 09:30 AM
uxojerry's Avatar
uxojerry
The TCI 6X is a six speed in a 4l80 casing. Fit is not a problem and has been installed in several C2s.
If there are any big block fans with EFI and overdrive, please let me know what kind of hwy mpg you are getting.
Old Jun 16, 2012 | 10:23 AM
zwede's Avatar
zwede
I got 21 mpg with an EFI 454 BBC and Tremec TKO. 75 mph is 2000 rpm.
Old Jun 16, 2012 | 10:48 AM
uxojerry's Avatar
uxojerry
21 mpg is great. I hope to hear of more people with this kind of mpg success.
To Old School Motor with EFI or LS
