Low RPM stumble. Timing?
So I got the car timed at about 12 initial as most recommend. At low RPM when gentle on the gas, the car stumbles a bit. Happens when starting from a dead stop, a slow roll and even when cruising at any speed and then gently apply the gas. Rhomp on it and everything is great, no stumble. Only when being gentle with it.
I had a friend help me re-time it. He races SBC on dirt track and does all his own motor work. He found that the car sounded smoothest at about 18-20 degree initial and about 50 overall. I didn't seem to have the stumble with that much initial timing, but I didn't give a chance. I didn't feel comfortable with reading everything on the forum.. I changed it back to 12 after he left my house..
What are your thoughts? When I asked why he had so much initial timing and not the standard 12, he said that it's a crap shoot with the mods I have on the car. he did agree that 12 is a good starting point but he felt like the engine sounded best and smoothest with the larger initial timing.
So I am back to 12 right now and getting the low end stumble. This is the first car that I have ever timed, so I am a complete amateur. Could the car actually need more that 12 initial and could the timing cause the low end stumble?
How to Set the Timing
When you think about it, setting the timing at idle speed makes no sense at all: You don’t operate your car at idle, and timing
changes as the rpm changes. Fact is, the timing spec at idle speed is provided as a simple way for most people to set the
timing, and is not a good procedure for optimum performance.
Small block Chevys (and most other GM performance V8 engines) perform best when the total timing (full centrifugal
advance plus the initial timing setting with vacuum advance hose disconnected) is all in by 2,500 – 2,800 rpm and is set to
about 36 degrees. If you have an adjustable timing light, this is very easy to check. If you don’t, you need to scribe a 36-
degree mark on your harmonic balancer. Here’s how:
Measure the circumference of your harmonic balancer using a sewing tape measure (or other flexible tape measure). Get it as
accurate as you can. Take this measurement and divide by 10. The number you get is the distance to 36 degrees. Measure
this distance CLOCKWISE from your existing harmonic balancer timing mark as viewed from the front of the engine and
place a clear mark on the balancer.
Remove your distributor cap and rotor. If you have a points-style distributor with the stock, factory, heavy springs in place,
remove one of the springs. Disconnect the vacuum advance. Install the rotor and cap. Loosen the distributor hold-down
clamp bolt just enough so that the distributor can by turned, yet leave it snug enough that the distributor will hold its position.
Start the engine. If you’re using an adjustable timing light, set the light to 36 degrees advanced. Now rev the engine while
observing the timing marks with the light. You will notice that the stock line on the balancer will move up towards the
timing plate as rpm increases. Continue to increase rpm until the line does not move any further (centrifugal advance is
“pegged out”). Once the timing is “pegged out,” the line on the balancer should line up with the “0” mark on the timing tab.
Rotate the distributor to achieve this.
If you’re using a non-adjustable light, perform the same process, but align your new 36-degree mark with “0” mark on the
timing tab.
Shut it down.
Pop the cap and rotor and re-install the spring, if you removed it. Put everything back together, but leave the vacuum
disconnected. Start it up. For future reference, make a note of the timing setting at idle. This is your new curb idle timing
spec. Now give the engine a few quick rev’s past 3,000 rpm and verify that the full timing (36 degrees) is coming in. If it’s
not, you need to change to a softer set of springs until you get full 36-degree advance before 3000 rpm. (NOTE: A stock set
of springs will often not allow full centrifugal advance to come in before redline rpm. If you have heavy stock springs
installed, don’t rev the engine beyond its limits to try to force full advance in.) I suggest obtaining Mr. Gasket kit part
number 927 or 928: Use the gold springs on HEI systems. For points-style systems, use one black spring and one silver
spring – these springs will get your total timing all in by 2500-2800 rpm, providing very good throttle response and power.
The black & silver spring combo can also be used on MSD distributors if you widen out the spring hook ends.
Hook up the vacuum. Re-set your idle speed and idle mixtures if necessary to lower the idle speed. Now do a road test.
The 36-degree 2500 rpm advance curve is optimum for performance, but may require premium fuel. Lug the car around, and
punch the throttle at low rpm while listening for detonation (“engine knock”). If you’re getting any audible knock, you
MUST retard the timing. Retard the timing in 2-degree increments until engine knock stops. Engine knock will seriously
damage engine components if not corrected. If you get no knock, you may see slightly improved performance at 38 degrees
total timing. This is particularly true if you’re running at high altitude.
If you have no engine knock under acceleration, but the car “chugs” or “jerks” at cruising speed (light throttle application),
you are getting too much vacuum advance on top of the mechanical advance. You may need to change out the vacuum
advance diaphragm with a unit producing no more than 16 degrees of vacuum advance. See my paper on “Vacuum Advance
Control Units Facts and Specs” for more info on this.
Your timing is now set for best possible performance. Make note of the new setting, and use this for your future tune-up
work.
Lars’ Suggested Timing Specs for GM V8 Performance Applications:
• 36 degrees total timing (vacuum advance hose disconnected), all “in” by 2500 rpm
• 18 degrees initial timing at idle (vacuum advance hose disconnected). Note that it may not be possible to achieve the
18-degree initial spec with the 36-degree total without modifying the distributor advance stop system. It is more
important to achieve the 36 total than to hit an exact 18 initial. However, if your initial timing is very low (below 12
degrees) with the 36 total, it is important that you repair or modify your distributor in order to achieve correct engine
performance
• 16 degree vacuum advance control unit with a pull-in spec that allows the full range of vacuum advance to be pulled
in at the engine’s idle manifold vacuum level. Connect to manifold vacuum for most applications (this will allow
the engine to idle with actual timing at idle of 34 degrees).
What type of carb are you running? Even with the timing slightly retarded the car should not stumble as you describe. It seems you're seeing a lean condition on slight acceleration, so a carb setup may be in order: You may need to richen up the pump shot, transition circuit, or both - this is typically required after the mods you have performed.
Lars
V8FastCars@msn.com
I played around with it (left the springs alone for now). I am currently at 18 initial. Hits 36 pretty quick but I can get 38 out of it if I go up to about 3200-3300 RPM. No more stumble..
I am currently running an Edelbrock 600 cfm, electric choke. (# 1406) Edelbrock Performer Intake, Dart SHP Heads, Mild Comp Cam. I did not know what HP the engine had before I had it rebult (as the PO did some engine work) but I can say that it is not a night and day improvement. My weak point right now is the 3.08 rear end. But everyone is telling me that a new carb will prove to be a somewhat good investment.
Keep the shiny side up!
Scott
Edelbrocks seem to be a love/hate thing. People that love them say that the problems with Edelbrocks are operator error. I think everyone agree's that they are harder to tune, but are a beter carb IF you can get them working properly with your set up.
Not to start a new topic, but how do you go about picking out a new carb? Where do you start? cfm?
Scott
Scott
Ralph
