window regulator spring question
Old Jun 17, 2012 | 04:54 PM
biscuitville's Avatar
biscuitville
Default window regulator spring question
When my window is raised to the top, the regulator spring has no tension on it and comes off when the door is shut. Is it possible for these to wear out, or is it that I just don't have the tension set right?
It is out of a 73 on the passenger's side. Any help is appreciated.
Old Jun 17, 2012 | 06:32 PM
SIXFOOTER's Avatar
SIXFOOTER
sounds like you need to take up 1 turn on the spring, with the window all the way up
Old Jun 17, 2012 | 07:59 PM
terry82's Avatar
terry82
i had the same problem on my 82.i did not want to take off the regulator .On the post for the outside of the spring i put on a spacer .Anything that will make the post bigger to put more pressure on the spring will work.I used a piece of round plastic with a hole in it the size of the post .This may not be a factory fix but it has worked for several months.
Old Jun 17, 2012 | 08:08 PM
Peterbuilt's Avatar
Peterbuilt
Are you installing it like this?
Old Jun 17, 2012 | 09:43 PM
biscuitville
Pete - yes, I had looked at your photos (in couple posts people put your pics) several times before posting. I can't see that mine was any different from yours at that same point in the travel of the regulator. At the raised point though, the spring is simply way too loose.
Sixfooter - can you elaborate? Are you saying to push the window one turn too far up an then install the spring?
Terry - sounds good. This line of thinking is what made me wonder if the spring didn't have the right tension.
Thanks to everyone for their replies - keep them coming, love this forum,
AL
Old Jun 18, 2012 | 08:53 PM
biscuitville
Default issue solved
To those who were interested - I simply bent the spring a little to effectively make it a little larger. Everything seems to be working fine.
Old Jun 18, 2012 | 09:39 PM
Peterbuilt's Avatar
Peterbuilt
Default A happy ending!
Well done, check that off the to-do list.
Old Jun 18, 2012 | 09:44 PM
terry82's Avatar
terry82
i think that is a great idea .i tryed to bend it, it was to tough for me .
To window regulator spring question
