New ZZ4 High Temp
Old Jun 21, 2012 | 11:56 PM
sgentry's Avatar
sgentry
7th Gear
Default New ZZ4 High Temp
So I've recently dropped-in a new ZZ4 crate engine, with hooker side exhaust, and the engine temp is running up to 220 within a few minutes of running at idle. I have the temp sensor in the original location, on the side of the block next to hooker headers. It appears to me that the heat from the headers may be affecting the temp sensor. The temp gun doesn't show the temp getting very high on top at the intake manifold and the radiator isn't very hot. I've replaced the thermostat to rule that out.
I'm wondering if I should move the temp sensor to the intake but I'm concerned that maybe there is a different problem and moving the sensor would give me a false sense that everything is ok. Obviously don't want to damage a new engine. Anybody else have issues like this or suggestions? Thanks in advance!
Old Jun 22, 2012 | 01:50 AM
cv67's Avatar
cv67
St. Jude Donor '05
You answered your own question on headers/high temp reading
its not running 220, promise!
Old Jun 22, 2012 | 08:13 AM
scottw's Avatar
scottw
The original temp unit does not fit on the original location for the ZZ4. Temp unit is too big. You may have a smaller one that does not have the same Ohms as an original, therefore, an inaccurate reading. I put mine on the intake. It runs about 15-20 degrees cooler going through the intake than if you had it in the original block.
Old Jun 23, 2012 | 02:25 AM
sgentry's Avatar
sgentry
7th Gear
I did buy a new sensor. I think I'll try putting the old sensor in the intake and see what happens. Thanks for the response!
Old Jun 23, 2012 | 03:39 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
ALSO- consider that you didn't remove all the air from the water side of the cooling system. With air in the system, it will spike high and stay there even after the T stat opens. Make sure you've purged all the air from the cooling system.
My ZZ4 temp probe is in the intake manifold also. It never goes over 180 degrees.
To New ZZ4 High Temp
