Vacuum advance issue
In trying to trouble shoot, I started working backwords, putting things back to the way they were before I started playing around with it...I put the vac hose back over to the venturi vac port, on the passenger side, which yields NO vac advance at idle, but keeps my total timing at 34 deg above 2,700 rpms. Also, the timing does a smooth increase, from the base of 16, up to 34, as the rpms climb, rather than the jump I get when running it on manifold vacuum. Problem with the venture vac, however, is the timing is retarded at lower rpms, resulting in hot exhaust, resulting in ruined spark plug boots, even WITH wrapped headers, boot protectors, etc.
Any ideas, thoughts, where did I screw this up?
http://www.lbfun.com/warehouse/tech_...ance_Specs.pdf
Re-read the timing sticky...
Carter
