Vac expansion tank
Old Jun 22, 2012 | 09:50 PM
ATIS's Avatar
ATIS
Default Vac expansion tank
I have a 75 and after sitting for 5 days I went to raise the lights to clean them using the bypass switch under the dash and nothing happened. I had to start the car and rev her a couple of times to get enough vac to open them. Is that normal or do I need to start chasing a leak?? thanks in advance.
Old Jun 22, 2012 | 10:14 PM
bashcraft's Avatar
bashcraft
You can look for a leak, but I'd consider it normal for a 37 year old car.
Old Jun 22, 2012 | 10:58 PM
ATIS's Avatar
ATIS
Wasnt sure. I will check for a leak but wont rush on it.
Old Jun 23, 2012 | 02:27 AM
7T1vette's Avatar
7T1vette
With the vacuum system in 'decent' condition (no major leakages; all components functional), vacuum can leak off fairly quickly. Not many new C3's would hold vacuum for more than a day. If all your vacuum systems work when engine is running, consider yourself either lucky or good (if you did the diagnosis/repair work).
Old Jun 23, 2012 | 07:49 AM
71scgc's Avatar
71scgc
It was my understanding that it would only hold enough residual vacuum for perhaps one action (headlights and/or wiper door) and only for a limited time, i.e. a few hours.
I certainly wouldn't worry over it, and would invest my worry time in things like "How can I make this thing haul a$$?!"
Carter
Old Jun 23, 2012 | 10:07 AM
'75's Avatar
'75
Carter
To Vac expansion tank
