Grind in first gear...sigh
If you can get the side cover off and look at the reverse idler teeth you can see a groove in the middle of the chamfer...
I see this on about 10% of the Muncie's I rebuild...
If you have a Hurst shifter with shifter stop bolts, adjust the rear stop bolt in a little bit, to limit the shifter from pulling the slider too deep into gear...
Hope this helps... Crash
Try to put it back...the threads are wiped.
If you pop the hood, and press down hard on the brake and give it some gas while in gear, does the engine move more than it should? Dead giveaway for a bad motor mount.
Keep the shiny side up!
Scott
So, it was, and IS, DEFINATELY the fan hitting the shroud...I have bits of shredded shroud to prove it! I popped the hood, and had a guy watch while I put my left foot on the clutch, then tried to maneuver my mammoth right foot onto both my brakes, and push into the throttle, and then carefully began lifting off the clutch. I gave it some decent gas, though no where near 1/4 throttle, when combined with the fact that I couldn't get my foot all the way off the clutch without stalling...but my partner said there was no movement with the engine. So, I figured maybe it's NOT bad motor mounts, but simply bad alignment with the fan shroud as mentioned by someone earlier in the thread. I read their post, and their reference to the three bolts to adjust the front nose, and got under my car, and tried to adjust it that way, with, what I must say....minimal results or success. So........I bubba'd it. I took off the top brackets that hold the shroud behind the rad, and drilled them wide, turning holes into slots, and then moved the shroud over more to the driver's side, making the clearance to the fan more even all around. Problem solved, right? Nope. I get in the car, go for a ride, press the throttle past 1/4 or so in 1st gear, and grind! I can hit it till the secondaries come in in 2nd, and then grind, the moment they do, which is around half throttle, or so. So it's just GOTTA be bad motor mounts, which, fortunately for me, I already had on order. But they are STILL not here yet.
Anyway, for future people who have problems with fan shroud alignments...and the motor mounts are NOT the issue, try slopping the holes in the brackets. That has my shroud lined up perfect.
Scott
I always wanted to try and modify the drum and parking shoes to make them lock into one another so you could depend on them but never got around to it. First thought was to drill some large holes in the drum and add studs to the shoes,it could only be applied when stopped but would hold solidly,disengagement might be a problem though.
One of these days.
