Grind in first gear...sigh
It's not a constant grind. For instance, I can ride the clutch slightly, to just start creeping forward, and no grind. When I lift off the clutch to engage the gear, though, little bit of grind when I gas it slightly. Then, once I'm moving along in 1st, no issues. Also, I can shift from 2nd to 1st without any grind. It's only happening from a stand still start, and not all the time. And it's a light grind...like, I didn't know what it was, at first. Usually, if, say, I miss 3rd gear, or something, you can feel that grind through the stick, and in your seat. But this can only be heard, and strangly, it SEEMS like it's coming from the right hand side of the car, but that could be because I'm half deaf, lol.
Would this be a clutch issue, more than a gear issue? Love these cars...no sooner do I get the timing figured out, now I gotta learn how to either replace a clutch...or....I guess NOT replace a tranny just yet...
Kind of sounds like maybe the clutch isn't releasing completely or maybe dragging just a bit. Try the easy stuff first. Adjust the clutch, maybe pull the drain plug out of the trans and see how much junk (read chunks) has collected on the drain plug. An oil change won't hurt your trans anyway.
And, uh....dumb question here....but....I KNOW where the plug to DRAIN the thing is, but where would I FILL it from?
I keep going back to your initial post- won't shift into reverse without going to first. Reverse gear is on it's own shaft in the bottom of the trans. IF the gear teeth are not exactly lined up, it's really hard to get the gear engaged, by going to first, it makes everything move a little and helps get in to reverse.
I use the old 90w gear oil in mine- nothing special, I think it's GL-5 or something. Others probably use something else so ask around.
Your trans might only have a fill plug and no separate drain. Then you get a sucking device to remove as much of the old gear oil as possible. Then fill to the bottom of the plug's treads when car is level on jackstands.
You could always drill and tap the lower boss for a drain plug in case there's a next time.
You can see I have 2 plugs on my Muncie case:
What sort of sucking device is advised? I have a shop vac...but something tells me...I don't want 90 weight oil in my shop vac. If I siphon SOME, to get it started, and had the hose lower than the tranny, you think gravity will do the trick, like with gas?
Hey! I'm just kidding! One of the secrets to a successful marriage is for at least one of the partners to be good with money, so it sounds like you are in good shape there, which is good. And, all kidding aside, it is a very real phenomenon that women will sometimes become jealous of our 'vettes, if they think the 'vette is cutting in on the attention they get from you, so be sure not to take the wife for granted, buy her some flowers once in awhile, take her out to dinner, etc. Maybe say something like: "I was thinking of working on the 'vette this weekend, but instead, let's go to the beach!" That'll make her think she's getting the best of the 'vette, but don't lay it on too thick, women are vain, not stupid! (Sometimes I think they are smarter than we are, but then I just try to think about something else, nothing but madness lies down that road!)
I don't know much about manual transmissions, but I have read several posts in this forum that tell of problems similar to yours that were cured with a fluid change, so I'd say it's worth a try. A drill powered pump, such as already been mentioned, sounds like the best way to remove the old fluid. I don't think the wife would appreciate a $50 hooker hanging around, even if it's just for a fluid change. (Oh! There's a joke in there somewhere, but I'm not gonna touch it with a ten-foot pole!)
Keep the shiny side up!
Scott
That sounds more like your linkages are out of whack.
Try this, at idle, push in (disengage) the clutch, shift into 1st, then keep light pressure on the shifter (as in trying to push it farther towards 1st gear) as you slowly release the clutch. Do you feel a click or a thud in the shifter as you do this? Or perhaps does it even notch a little farther in?
