Half Shafts
Old Jun 27, 2012 | 06:15 AM
dpw21562's Avatar
dpw21562
Default Half Shafts
Where can I find "good" half shafts for an "80" . I've been looking and also have heard bad stories. Opinions please.
Old Jun 27, 2012 | 06:42 AM
gingerbreadman1977's Avatar
gingerbreadman1977
http://www.vansteel.com/index.cfm?fu...p=1002&ID=1466
http://www.ecklerscorvette.com/corve...1980-1981.html
Old Jun 27, 2012 | 09:45 AM
76stingracer's Avatar
76stingracer
There's a place in Fort Wayne that makes them new. Think they post a listing on ebay once in a while. Fort Wayne Clutch & Driveline I believe.
Old Jun 27, 2012 | 10:25 AM
7T1vette's Avatar
7T1vette
If your engine is putting out 450 hp or more, you also need to install safety retaining straps which surround those half-shafts. If you break a U-joint or twist/break a shaft, the remaining part of the shaft attached to the diffy will tear the he!! out of your underbody, if you don't.
Old Jun 27, 2012 | 11:19 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by dpw21562
Where can I find "good" half shafts. I've been looking and also have heard bad stories. Opinions please.
I didn't know there was bad ones. Example please?
Old Jun 27, 2012 | 11:42 AM
Red 69's Avatar
Red 69
Scroll down the Drag Vette link below and you will find new half shafts, safety loops and much more.
http://www.dragvette.com/products.htm
Fort Wayne Clutch has them also. Up to a couple years ago they were priced at $150 a pair, but then the price of metal went up, as we sent all our scrap to China.
http://www.fortwayneclutch.com/index.../corvette.html
If you are going to do any straight line racing, installing safety loops at the same time as half shafts makes sense.
The 3 inch half shafts are a direct fit as a replacement for the smaller diameter shafts used on early C-3 and C-2 Vettes. The 3 inch are stronger and clear up the good and bad shafts. Nothing bad about a 2 inch shaft, but as HP increased with sticky tire compounds, so did the number of twisted 2 inch shafts.
Old Jun 28, 2012 | 12:37 PM
dpw21562's Avatar
dpw21562
Default Half Shaft
Heard where the ones from Mid-America failed.
Old Jun 28, 2012 | 01:00 PM
Mike Ward's Avatar
Mike Ward
Like most parts, there's probably only one or two manufacturers who supply to all retail vendors. Who made the shafts that Mid America sells?
BTW- I'm not so sure that the 3" OEM shafts are any stronger than the earlier 2.5" shafts.
Old Jun 28, 2012 | 02:49 PM
MIKE80's Avatar
MIKE80
Bought mine from Dan over at Van Steel.
Old Jun 28, 2012 | 04:52 PM
FKING1's Avatar
FKING1
Put Fort Wayne heavy duty half shafts on my 500HP+ 383 last year.
Good pieces.
Old Jun 28, 2012 | 06:20 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Good pieces.
To Half Shafts
