Vortec Heads on a 1981?
Old May 26, 2002 | 12:30 AM
VETJET's Avatar
VETJET
Default Vortec Heads on a 1981?
Does anyone make an intake manifold that fits Vortec heads and also allows you to use the factory carbuerator on a 1981?
Old May 26, 2002 | 05:25 AM
szercer's Avatar
szercer
Default Re: Vortec Heads on a 1981? (VETJET)
nope, you have to get a new carb, you might need more cfm's anyhow
Old May 26, 2002 | 05:26 AM
1979toy's Avatar
1979toy
Edelbrock part number 2116 will get you a Performer Vortec intake for a Q-jet.
Old May 26, 2002 | 09:44 AM
74ZZ430's Avatar
74ZZ430
Scoggin and Dickey a GM dealer in Texas makes to a stock cast iron q-jet manifold that fits vortec heads, thats what I,m using. I couldn't find an aftermarket mainifold that was low enough to use the stock hood and air cleaner.
Old May 26, 2002 | 09:50 AM
Dalannex's Avatar
Dalannex
Default Re: Vortec Heads on a 1981? (74ZZ430)
Any Vortec manifold for a q-jet will work as long as a few things check out. You need provisions for EGR, there is a sensor at the front of the manifold, I don't remember if it's a temp sensor????? seems like it is. I'd have to go look at mine later, and deck height, you want to be able to close your hood. :cheers:
To Vortec Heads on a 1981?
