clutch fork pivot ball height
Old Jun 28, 2012 | 10:44 PM
3X2's Avatar
3X2
Default clutch fork pivot ball height
I'm in the process of installing a new clutch and flywheel. Using the formula from Centerforce to determine how tall the pivot ball needs to be. The answer I come up with is my ball is 0.060" too short. Will that 0.060" make that much of a difference or should I get an adjustable ball? Get a throwout bearing 0.060" longer? Or, leave it as is?
Mark
Old Jun 29, 2012 | 12:26 PM
gkull's Avatar
gkull
Right now it is .060 too short. In the future ware will increase that number as the plates, fingers, throw out face ware. I run the GM long pivot ball availiable at any dealer for $14.95 I don't like adjustables
Old Jun 29, 2012 | 12:35 PM
Surfer69's Avatar
Surfer69
GM long ball usually solves any issues but if you change flywheel thickness make sure to figure out if you should use 1.25 or 1.5 TO bearing.
Old Jun 29, 2012 | 01:03 PM
3X2's Avatar
3X2
Thanks for the replies. I also do not like the adjustable ball, but the scattershield already has the longer GM ball installed. I'll determine what length release bearing to get. I used the Centerforce measuring procedure to determine that the ball is too short. I "assume" the numbers given for the nominal flywheel deck height (0.0960') and ball distance to the engine block (4.750") are correct.
Old Jun 29, 2012 | 06:45 PM
gkull's Avatar
gkull
You can't assume. I have a similar setup and the long ball works.
Old Jun 30, 2012 | 11:47 AM
3X2's Avatar
3X2
Installed the new flywheel and clutch today. With the long stud and the 1.25" long bearing that came with the clutch, the bearing is tight against the pressure plate fingers. Swapped to the short stud and now I have too much clearence. Tried another bearing that is 1.75" long with the short stud and it too, is tight. I guess my next options are to either try to find a 1.5" bearing or go to the adjustable stud.
Old Jun 30, 2012 | 12:43 PM
Garys 68's Avatar
Garys 68
may be some help
http://www.novak-adapt.com/knowledge/clutches_etc.htm
To clutch fork pivot ball height
