Regulator Connector & Overcharge
Old Jul 5, 2012 | 04:58 PM
Joebrick's Avatar
Joebrick
Default Regulator Connector & Overcharge
During my last drive I found my ammeter showing a pretty serious overcharge (16V). So, my thought is a bad regulator. When I went to disconnect the 2 wire clip on the alternator, I found the top wire had broken off where it enters the connector.
My question is...could this broken wire be the cause of an overcharge condition? (top wire black and white striped)
I'm hoping so... since the alternator/regulator checked out OK on a bench test.
1973 L82
Old Jul 5, 2012 | 05:25 PM
7T1vette's Avatar
7T1vette
Yes, that's the 'voltage sensor' wire that lets the regulator know the car's system voltage. Since it was broken off, the regulator saw no voltage in the system and called for full charge condition.
Old Jul 5, 2012 | 05:37 PM
Joebrick's Avatar
Joebrick
Great...and Thanks! Found a connector at Advance Auto and once I splice that in...I should be good to go.
Hoping I didn't screw up my battery too badly. I ran this way for about 20 minutes so I could get home.
Old Jul 5, 2012 | 05:49 PM
7T1vette's Avatar
7T1vette
The 20 minutes at that voltage should not do any significant damage to the battery.
To Regulator Connector & Overcharge
