Help me identify where this u-clip goes
Hey guys. 1975 Coupe. Just replaced driver's inner door handle mechanism. This clip came with it. Where in the world does it go?
As I recall, there is two notches cut into the back of the **** that the clip fits into. Put the clip in the groove before pressing it onto the spline. You need to orient the **** before placing it, or you will need to pull it off and start over.
If you orient the **** or handle in the wrong position you need this tool
to remove the clip.
Open mouth of the clip will face the open mouth of the tool.
Then push tool towards the clip. tis will cause clip to spread and push off the handle or ****.
to remove the clip.
They are very light and tend to fly across the garage when you least expect it, never to be seen again.
You can find extras in the Help! section at the parts stores...ask me how I know...
