Toyota 4.3
Old Jul 8, 2012 | 12:02 PM
rockrdr's Avatar
rockrdr
Default Toyota 4.3
Hello everyone,
I just picked up my 1st Corvette, I got a 75 coupe, still doing research on it but I have wanted one since I was a kid. its a project but I think it is in pretty good shape. It has a small block not orig im pretty sure since it had a "PepBoys" manifold on it with an edlebrock carb. I'm still looking into it..
So everything I read the 75 seams to be a bastard step child, is this correct?
What kind of mileage am I to expect?? I know I will probably kick banned for even mentioning this but I was thinking of putting a Toyota 3.4 in it. good gas mileage and pretty good power. Thoughts?
Jason
Old Jul 8, 2012 | 12:32 PM
oldalaskaman's Avatar
oldalaskaman
thats an excellent idea, please post pictures as you do the swap
Old Jul 8, 2012 | 12:35 PM
johnt365's Avatar
johnt365
Good luck with your gelded stallion.
When you think about putting that 4.3 or 3.4 motor in it you need to consider the car it was in when you factor the fuel economy. A corvette aint light, that will effect the economy of the engine.
You could also find a wrecked Smart car and put one of their motorcycle engines in your muscle car... Think of how easy it would be to work on with all that room under the hood.
Or heck, since you will be welding anyway, why not take the motor out all together and then cut holes in the floor boards and go Fred Flintstone style. It doesn't get any greener.
Priya's Avatar
Priya
If it was a great deal cheaper than it is I'd put a Ford Eco-boost six in my Corvette.
Old Jul 8, 2012 | 12:41 PM
Learning_Curve's Avatar
Learning_Curve
A fuel injected v8 from a newer vehicle along with an overdrive transmission can get close to 30mpg. I'm swapping an LT1 in my '76, and while it doesn't drop just in its still an easier change.
Remember this is a Corvette. If you really want a toyota 6 cylinder, how about a Supra engine?
Old Jul 8, 2012 | 12:53 PM
oldalaskaman
I believe I saw a yugo for sale on craigs, should be a good swap also.
Old Jul 8, 2012 | 01:16 PM
rockrdr's Avatar
rockrdr
Default Weight
I had a T-100 pickup great power and gas mileage, curb weight is 3550 and the curb weight of the corvette is 3660. it was just a thought. not trying to go green just trying to save cash. all flamed responses set aside, other ideals?
Old Jul 8, 2012 | 01:38 PM
tfi racing's Avatar
tfi racing
I would like to see this too,how do plan to make the EFI and PCM function properly when its not in a Toyota?
Old Jul 8, 2012 | 01:42 PM
rcread's Avatar
rcread
How much do you intend to drive your car? The cost to transplant a 3.4 into your Corvette would pay for a lot of gas. From doing a little quick research, it looks like the 3.4 gets 26 mpg on the highway in a Tacoma. The Tacoma is actually quite a bit more aerodynamic than the Corvette, so it won't get as good mpg in a Corvette body. Properly tuned and with a modest rear end, your Corvette should be capable of 20 mpg with the V8. You'd have to drive a ton of miles to justify the cost of the engine swap from an economical standpoint.
BKbroiler's Avatar
BKbroiler
If you're serious about that you don't deserve to own a Corvette.
Old Jul 8, 2012 | 01:50 PM
johnt365's Avatar
johnt365
all flames aside. I think the conversion will be pretty intense. Your 3.4 truck has 190 hp and an overdrive transmission. With a few minor changes, that 350 could easily see 190+ hp and all your accessories would be there, parts are at any local parts store and there is no other engine that has more aftermarket parts.
If you change the motor you gotta change the transmission as well. If it was me, I would
swap the transmission to a 700R4 which has an overdrive and fun low first gear,
duel the exhaust and put in headers,
tune it up and recurve the distributor.
That should put you at about the same power as that 3.4 and give you an overdrive which is what is making that T-100 get the good MPG. If you drive the T-100 around for a day or so in 3rd gear you should get an idea of what is killing the Vettes economy.
If you still want to do this, consider that it is not uncommon to see Corvette motors in other cars. After all, a Corvette is just a big fiberglass container for your engine. Yes, there is no cooler looking car than a Corvette. However, just imagine the deflated smiles and empty looks of confusion as you pop the hood to flash that rice motor to your friends.
Old Jul 8, 2012 | 02:12 PM
rockrdr's Avatar
rockrdr
lol true, I guess ill work with the small block a while till she blows then look into it further. maybe ill look into the 700r4 or some of these 6 speed swaps..
Old Jul 8, 2012 | 05:32 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
If you are considered about gas mileage, go buy a Prius instead, a Corvette and gas mileage cannot be used in a single sentence.
Old Jul 8, 2012 | 05:35 PM
rockrdr's Avatar
rockrdr
I'm sure all you rich guys that can wipe your butt with hundred dollar bills can afford these porches and new vettes, but us lil guys that actually work for a living and have wanted a corvette and just happened to be in the right place at the right time to get a deal; doing what they can with what they got.... i came here for help, ideals and research. I don't think I could get a prius for 1200
Old Jul 8, 2012 | 05:40 PM
Priya's Avatar
Priya
That's a defeatest attitude. You can always improve upon what these originally did, in some cases substantially so.
Old Jul 8, 2012 | 05:44 PM
damoroso's Avatar
damoroso
You don't typically buy a C3 for its fuel economy. Rather than insult (agreed that's only my silly opinion) the legacy of the only Amercian sports car by installing a Japanese engine, why not do an LS swap that will give you horsepower and economy? You can easily run 400hp and still get around 28mpg. On top of everything else, I'd bet the LS swap would be much more cost effective.
Old Jul 8, 2012 | 05:59 PM
'75's Avatar
'75
Yours maybe, not mine!
To Toyota 4.3
Old Jul 8, 2012 | 06:14 PM
lionelhutz's Avatar
lionelhutz
Same as what I posted about the guy thinking a 4.3L would be such a great swap because it'd be unique and save so much fuel. Unique isn't all it's cut out to be. The Toyota engine is a dog compared to your other options, just like the 4.3L is a crappy engine to start with. An LS engine isn't just a drop in either but the swap is documented and one of them will perform better and give better fuel mileage. There are good reasons many people are using the LS engines for many swaps.
Old Jul 8, 2012 | 06:28 PM
myoriginal77's Avatar
myoriginal77
For less than $1200 you can pay the difference in MPG for a long - long time, and as you work for a living, you should appreciate the time and aggravation saved along with the money ...
Frank
Old Jul 8, 2012 | 06:47 PM
sweeet76's Avatar
sweeet76
I wouldn't know about butts and hundred dollar bills, but I've seen porches attached to some of the worst looking buildings and some even had Vettes parked in front.
