FWIW, I didn't think I was having engine problems until 4 years ago when I took the heads off for inspection from my 1969 oem 350/300 (w/3.08 gears) with under 90K miles. I bought it with 40K miles so I don't know how the care was before that but, I did 3-4 month changes when using it as a daily driver in the 70's with name brand zinc fortified oil available back then.
This almost looks like pitting from corrosion, not wear from lack of Zinc?
What did the cam look like?
I'd also be curious what the bearings looked like..
Yikes!
Yikes!
Never got that far on inspection - opted for a ZZ4 (with a roller cam) and put the oem engine on a skid.
Again, FWIW, car ran great before teardown. I was more concerned with cylinder wear/scoring which seemed virtuially non-existent.
I own a 1978 corvette with a 350 L-82 motor , I use mobil 1 10/30 fully synthetic motor oil . Do I need to use the zinc additive ? I was told to use a 4 oz. bottle of zdd plus, zinc additive by my corvette guy...
