Door panel removal?
Old Jul 9, 2012 | 06:26 PM
DCSouthwind's Avatar
DCSouthwind
Default Door panel removal?
Anyone know where I can find a good article on how to remove the door panel on my C3? I am ordering new panels and want to do it myself. Pictures would be nice.
Old Jul 9, 2012 | 07:30 PM
dgood's Avatar
dgood
DC,
do you mean the interior door panel? If so, there are there screws that hold the arm rest on, two where you rest the arm and one by the top of the arm rest. There is one screw that holds the little panel behind the interior door handle. You will have to undo the 4 screws that hold the mirror adjustment **** on and once you pull the **** out, there is a little allen screw that you need to take off.
Some times there is a screw at the bottom of the panel back by the door opening. YOu should be able to lift the panel up and out.
If you are talking about the "skin" of the door you are on your own there.
Old Jul 10, 2012 | 04:22 AM
DCSouthwind
Thanks dgood. No it is the inside door panels.
Old Jul 10, 2012 | 06:55 AM
RedZR's Avatar
RedZR
Removing them is one thing, but I always wondered about installing new ones. Are the screw (attaching) holes and other cut out areas for the power window switch already drilled in the new door panels? If not, how do you get them drilled in the right place?
Dan
Old Jul 10, 2012 | 10:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by DCSouthwind
...Anyone know where I can find a good article on how to remove the door panel on my C3?...
Order the assembly instruction manual (AIM) and take a look. The AIM shows how the panels were installed at the factory. Removing them is the opposite.
You have trim screws, arm rest, door handle, lock, velcro fasteners, etc. to deal with.
The AIM will pay for itself. You'll use it for more than door panels, i.e., it shows how your CE graphics package was installed.
Old Jul 10, 2012 | 04:58 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
It depends on the year of your car. The older ones are pretty easy. For my 1970, what I had to do was remove the 4 screws around the edge, two screws holding the door pull on, and you have to pop off the "Jesus clips" on the window crank and lock ****. Then the panel slides off of the handle. Based on the picture in your avatar, your car is probably too new for that.
Old Jul 10, 2012 | 05:01 PM
Jedi926's Avatar
Jedi926
got an AIM for $20 on Amazon.
Old Jul 12, 2012 | 12:56 PM
DCSouthwind
Thanks! Ordered my AIM
Old Jul 12, 2012 | 02:01 PM
Easy Mike's Avatar
Easy Mike
It will entertain you after it arrives.
Old Jul 12, 2012 | 03:09 PM
dgood's Avatar
dgood
Go to the willcox website and they have instructions on how to do it. Type in door panel in the search engine on their website and at the bottom of the page you will see the instructions.
http://willcoxcorvette.com/advanced_...+panel&x=0&y=0
To Door panel removal?
