1972 Radio
Old Jul 9, 2012 | 08:00 PM
Donny72's Avatar
Donny72
Default 1972 Radio
If one (ME) wanted to test a stock radio that I got with my car, how would I do that WITHOUT hooking it up in the car? I guess I am asking how to bench test it. What wires go where? Thanks!
Old Jul 9, 2012 | 11:31 PM
7T1vette's Avatar
7T1vette
Well, first off you would make sure that the convector is properly connected to the radio and that speakers [8-10 ohm impedence, low wattage] are connected to the two pairs of green/black wires (one set has light green, the other dark green...if I remember correctly). Then, you need to plug in an antenna to the pin connector on the right-rear (as you are facing the dial) and supply power and ground to the unit via the orange/yellow/black connector. Then you turn it on and tune it in!
Old Jul 10, 2012 | 08:16 AM
1986coupe's Avatar
1986coupe
Old Jul 10, 2012 | 09:46 AM
Mashman's Avatar
Mashman
I believe the connector colors are Grey/Black/Yellow - I don't believe that there should be an orange wire.
Grey = illumination
Yellow = power
Black = ground
Old Jul 10, 2012 | 09:59 AM
7T1vette's Avatar
7T1vette
I think you are correct. Yellow is the switched 12vdc power line, gray for the dial light, and black for ground. Thanks for the correction.
To 1972 Radio
