Measuring driveline angle
Old Jul 9, 2012 | 08:07 PM
Learning_Curve's Avatar
Learning_Curve
Default Measuring driveline angle
So I've swapped in a T-56. When I modified the crossmember I set the mount height as low as possible, knowing I could always shim the tailshaft up to fine tune the u-joint operating angles.
Well I've measured the front u-joint, and it only has maybe 2 degrees of operating angle, but I don't know how I can measure the rear u-joint angle because of the diff mount and rear frame crossrail. Anyone ever done this?
Old Jul 9, 2012 | 11:43 PM
texas jim's Avatar
texas jim
After getting the engine & trans, transfer case and rear housing basically square to the frame, level and square w/ one another, then you get more indepth to phase-in the drive line. Using the angle finder, you get the trans tail shaft parallel to the axis of the pinion gear, both in the horizontal and vertical planes.
You MUST get that angle finder on the yoke where the bolt holes are inorder to get an accurate reading. From what you've said, you only have a problem on getting on the yoke of the differential w/ the tool.
I've used this article I have a number of times over the years, refreshing my memory everytime after the first. The article is indepth and covers the whole process from start to finish excluding nothing. The magazine/book is somewhere between 20 and 30 plus years old-can't remember where I was when I bought it. It's a "Hot Rod magazine's ENGINE." The "Hot Rod High Performance Series" Volume 3 Number 1.
If you can't find this magazine/book and need this article f/ further work, just get back w/ me and I'll get the article to you, even if I have to copy and mail it. But it seems you're over as far as getting it all done, w/ that small exception of not getting the tool on the yoke.
Best of Luck to you, sincerely...
Old Jul 10, 2012 | 02:38 AM
pauldana's Avatar
pauldana
did it with a lazar... here is the post:
http://forums.corvetteforum.com/c3-t...lso-still.html
Old Jul 10, 2012 | 04:22 AM
Garys 68's Avatar
Garys 68
IIRC, I had to use a mirror to see the the angle finder once it was on the yoke. Also discovered the original driveline was near 0 degrees. I cut down the front rubber diff mount to get the front of the diff up to match the trans down angle.
Old Jul 10, 2012 | 11:43 AM
Learning_Curve
I guess I'll have to pull the driveshaft if I to get a good measurement. My original thought was to wait until the driveshaft was in so I could get the u-joint operating angle as well. So now I can only measure off the u-joint cap, which is blocked.
I think I'll just wait till the maiden voyage and see if I have any vibration.
Old Jul 10, 2012 | 01:51 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's what I have 2 degs, you will probably be ok
Old Jul 10, 2012 | 04:00 PM
Garys 68's Avatar
Garys 68
I think you may want to put the T56 up as high as possible. You have a down angle now and your diff is probably flat at 0 degrees.
Old Jul 11, 2012 | 08:26 AM
The Money Pit's Avatar
The Money Pit
When I put the th400 in, I made a 90 degree aluminum plate that I bolted to the pinion flange. It extended forward about a foot, and allowed me to tape a print out of a compass I downloaded. Using a string and weight, I was able to measure the pinion angle with the driveshaft out.
If I remember the angle was negative one, and I needed to raise my tranny tailshaft about as high as I could to get a positive one degree angle.
Old Jul 11, 2012 | 08:45 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Great idea!! I like it. I tried and tried to get good measurements on mine and could never really get good numbers out of the rear pinion. I just kept adjusting the trans up and test driving till the vibs were gone. I am going to try your method and see what I can come up with now. I have some left over angle from when I put in new garage doors that should work with a magnetic base and an angle finder. Thanks for the idea.
Old Jul 11, 2012 | 11:02 AM
jnb5101's Avatar
jnb5101
screw a long bolt into the yoke where the cap bolts on, and measure the angle of the bolt. i got a magnetic angle gauge from harbor freight that is about 1 1/2" square, and i just hang it downwards from the bolt. i used it to set my caster on my front alignment.
To Measuring driveline angle
