where does this wire go?
Old May 27, 2002 | 02:53 PM
ykp53's Avatar
ykp53
Default where does this wire go?
i have a electrical connection on the a/c compressor, and one on the pressure switch on the passangers side wheel well, but i cant figure out how the wires should be run. i only have three wires that are not connected in the engine bay, a green , a black, and a white. Any guess on how they should be connected. Also what is the difference bettween a c.c.o.t and a V.I.R. evaporator. thanks
Old May 27, 2002 | 03:22 PM
Corvettes White's Avatar
Corvettes White
Default Re: where does this wire go? (ykp53)
If I recall correctly they run in series. That way if the system goes high-pressure, power is cut to the compressor clutch.
George
