1976 Mirrors
Old Jul 12, 2012 | 03:56 PM
hotrod3274's Avatar
hotrod3274
4th Gear
Default 1976 Mirrors
How can I get the side mirrors from moving in the wind? They won't stay adjusted, too loose.
Old Jul 12, 2012 | 04:22 PM
jcloving's Avatar
jcloving
Edit: Post #4 has the procedure you need. Thanks to 7T1Vette.
http://forums.corvetteforum.com/c3-t...de-mirror.html
If the movement is at the body, the mount to the door could be loose. I had this problem and I had to make the two screws to the door very, very tight. It worked.
Good Luck!
