Hi I am new here thanks for letting me join..My question is what size bolts /nuts go from flywheel to torque converter on an 1981 corvette automatic...??
Welcome to the forum. I guess the first question is, is it a stock converter? I have fond that different converter require different size bolts.
If no one can answer you. you can use a standard bolt to find the tread size and then buy "torque converter" bolts to match. Torque converter bolts are specif for that use. Hope this helps some at least it will get you back to the top.
