Can a 305 cause an almost 100 lb decrease in weight?
Old May 28, 2002 | 01:53 AM
Golden80's Avatar
Golden80
Default Can a 305 cause an almost 100 lb decrease in weight?
Just an odd-ball question.
The stock weight for my car is rated at 3495. But that's with the 350. Is the 305 that much more light? :confused: I measured mine at the track and it came in at just under 3400.
Matt
Old May 28, 2002 | 01:57 AM
Tom73's Avatar
Tom73
Default Re: Can a 305 cause an almost 100 lb decrease in weight? (Golden80)
Base weight for an 80 is 3,336 lbs, Per the Corvette Black Book. To that you would add the weight of options. I cannot see the 305 being lighter unless it may have a smaller radiator and cooling system and/or smaller exhaust pipes.
tom...
Old May 28, 2002 | 02:48 AM
blackLS1's Avatar
blackLS1
A 305 came ina Vette??? :confused: If not why did you chose that engine combo?
Old May 28, 2002 | 02:52 AM
Tom73's Avatar
Tom73
Default Re: Can a 305 cause an almost 100 lb decrease in weight? (blackLS1)
305 was used in 80 in Calif Vettes for emission reasons. :( They were 180hp, just ten off of the base L48's 190hp.
tom...
Old May 28, 2002 | 02:59 AM
Sting Raycin's Avatar
Sting Raycin
Default Re: Can a 305 cause an almost 100 lb decrease in weight? (Tom73)
Maybe you have more air in your tires than it did from the factory :lol: :lol:
Old May 28, 2002 | 08:44 AM
shotgun_000's Avatar
shotgun_000
Didn't some of those 305's have lightweight heads? :confused:
To Can a 305 cause an almost 100 lb decrease in weight?
