Alternator bracket
Old Jul 17, 2012 | 09:08 PM
dpw21562's Avatar
dpw21562
Default Alternator bracket
Where can I find an alternator bracket for my "80" on the drivers side using a long water pump. The motor is a custom built motor not stock. Thanks.
Old Jul 18, 2012 | 09:23 AM
stingr4y's Avatar
stingr4y
Matching up brackets can be a pain.
Perhaps more info please.
Why can you not use the original brackets? If I remember correctly, you are swapping the alt to the other side right?
Are your other accessories aligned ok? What are they? Small block?
I found a guy in town that had a bunch of old brackets. It gave me the option of just borrowing and trying them out. I bet if you ask around, you can find someone that can at least get you close.
Old Jul 18, 2012 | 12:21 PM
dpw21562's Avatar
dpw21562
Default Alt nracket
355 in. LWP want alt. on drivers side. Original bracket went with the original motor.
To Alternator bracket
