clunking noise still present
Old Jul 17, 2012 | 11:26 PM
bdk2580's Avatar
bdk2580
5th Gear
Default clunking noise still present
i have an 82' and recently replaced everything in rear suspension, all poly bushings, wheel bearings, brake calipers, mono spring, half shaft u-joints and still have the mysterious clunking noise. it presents itself either when turning at low speeds or while taking off from a stop or while shifting through the gears and also while shifting between P,R and D. any suggestions as to what the cause is will be greatly appreciated.
Old Jul 17, 2012 | 11:39 PM
1986coupe's Avatar
1986coupe
Did you do the drive shaft u-joints?
What is the condition of the rear end? How is the fluid in it?
Old Jul 18, 2012 | 02:08 AM
totallygoingsofast's Avatar
totallygoingsofast
1st Gear
I had a similar clunking noise on my 77 that turned out to be the result of really worn pinion snubber cushions. How do yours look?
Old Jul 18, 2012 | 06:45 AM
bdk2580's Avatar
bdk2580
5th Gear
changed fluid plus a bottle of additive in differential. changed snubber cushion. have not changed drive shaft u-joints yet. going to try doing figure eights in local parking lot. can't wait to see the locals staring and wondering.
Old Jul 18, 2012 | 08:13 AM
hugie82's Avatar
hugie82
I'm thinking posi clutches in the rear
Try some GM posi additive ...
Old Jul 18, 2012 | 09:28 AM
77vetteluva's Avatar
77vetteluva
My first thought was the posi-clutches because of the noise turning but since you have added additive and it happens when shifting between directional gears I'm leaning towards u-joints. Let us know what you find.
To clunking noise still present
