Lock distributor (EFI)
Old Jul 18, 2012 | 03:18 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default Lock distributor (EFI)
Planning ahead for next winter:
I'm going to add ignition control to the Holley HP EFI
Is it relatively simple to lock a mechanical + vacuum advance distributor or am I better of buying something like a small cap HEI?
Old Jul 18, 2012 | 03:23 PM
MelWff's Avatar
MelWff
you can disconnect the vacuum line and tack weld the advance, doesnt the system abandon the distributor all together for individual coils for the cylinders?
Old Jul 18, 2012 | 03:36 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
If you use a crank sensor, yes.
Old Jul 18, 2012 | 04:55 PM
zwede's Avatar
zwede
You can get a rebuilt small cap HEI for $100. Why mess with your old one?
Old Jul 19, 2012 | 03:51 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
That's not including coil, are the canister coils compatible or do I need a specific HEI one?
Old Jul 19, 2012 | 04:04 PM
MelWff's Avatar
MelWff
is this the system you are referring to and did you read this manual?
http://www.holley.com/data/TechServi...R10555rev3.pdf
Old Jul 19, 2012 | 04:18 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Yes, that's the one, and yes, I read the manual.
It covers how to wire up each version, but doesn't discuss locking dizzy vs small cap HEI
To Lock distributor (EFI)
