C3 Brake problems
Old Jul 18, 2012 | 08:40 PM
yatsguy's Avatar
yatsguy
3rd Gear
Default C3 Brake problems
OK, looking for some advice, installed new calipers, booster and master cylinder, the only thing left is prop valve. Brakes hold firm without engine running, with engine running ...as I rev it in park, the brake pedal slowly goes down... What is happening... My gut says booster or vacuum problem, but It was replaced ? hint- I replaced booster about a year ago, but never finished the brake work (I relocated and could'nt get to it).
Old Jul 18, 2012 | 09:10 PM
Greatsteaks's Avatar
Greatsteaks
It is suppose to do that. If the peddle does not get softer when you start the engine the booster is bad. If it goes all the way to the floor then you have a leak or air in the mc or brake lines/calipers.
Old Jul 18, 2012 | 09:28 PM
1986coupe's Avatar
1986coupe
Check for leaks. Also check for air in the system. You did bleed both bleeder screws on each of the rear calipers?
Old Jul 18, 2012 | 11:28 PM
yatsguy's Avatar
yatsguy
3rd Gear
Default Thanks
Thanks for your input, I have bled about 2 quarts of brake fluid through the system and no external leaks, thats whats throwing me a curve. And as I rev the engine the pedal will slowly go to the floor, have'nt tried to drive yet, but want to be sure I can stop?? And I bled it from all 6 bleeders until I made sure no air in lines.
Old Jul 18, 2012 | 11:31 PM
yatsguy's Avatar
yatsguy
3rd Gear
Default further thoughts
SO I guess I need to know if the prop valve is faulty, what would be symptoms, and if booster is faulty, what are the symptoms...
Old Jul 19, 2012 | 06:10 AM
63split63's Avatar
63split63
If there are no leaks and no air in the system I would suspect the master cyl.
Bill
Old Jul 19, 2012 | 10:25 PM
texasbaehr's Avatar
texasbaehr
Don't get insulted now but, Did you bench bleed and prime the master cyl. before installing. It happens a lot!
To C3 Brake problems
