4sp stuck in reverse?
Old Jul 20, 2012 | 11:12 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default 4sp stuck in reverse?
last night, I started the car and when I let out the clutch (shifter in 1st), nothing happened then car stalled.
Put shifter into neutral, let out clutch, car starts going backwards.
Arsed around with the shifter and the reverse release, seemed to change nothing.
Eventually I got a little more violent with the shifter and it seemed to pop out of whatever state it was in.
Everything is now back to normal.
Is this a common issue?
Old Jul 20, 2012 | 11:26 AM
restoman1's Avatar
restoman1
Yep. Your shifter is worn. Do you have the original or a Hurst? Either way you need to rebuild and regrease it.
Ed
Old Jul 20, 2012 | 11:37 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Original AFAIK
Old Jul 20, 2012 | 12:24 PM
Mike Ward's Avatar
Mike Ward
A worn shifter can allow the transmission to be in two gears at the same time, usually reverse and first. Time to rebuild it.
Old Jul 20, 2012 | 12:49 PM
restoman1's Avatar
restoman1
HERE'S the instructions and of course, you'll need one of these REBUILD KITS, but it's not that difficult to do.
Ed
Old Jul 20, 2012 | 01:03 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Excellent, thanks.
To 4sp stuck in reverse?
