Help me pick a cam 454
I prefer the older style grinds not the fast ramp "extreme" type stuff
268 high energy (dual energy?Been awhile) comp or the 270 Isky mega cam personal all time favorite being as you have a stick.
Youll hear a slight rump but nothing heavy. Comes on real nice upper bottom to midrange
The 71 and 72 454/365, 270 and 240 engines, which also had 8.5:1 compression, used the 3904359 cam which was listed as having a .461 lift for the intake, and .480 lift for the exhaust. (This was the same cam used in the 1970 454/390 engine, but was 10.25:1 compression instead of 8.5:1)
I can see no reason you couldn't use that cam in your engine since all these engines used the same basic open chamber heads (although different part/casting numbers) with 2.06/1.72 valves, 113cc's and 8.5:1 compression ratio.
Now, I'm not recommending one brand of cam over another, but I've used the Summit house brand kit's in three of my engines and love them. For awhile, when I was commuting to work in my 68 Camaro (396), I was using the SUM-K1300 kit. It's great for low end torque and gas mileage. With that cam, a 6210 Holley, a Holley Street Dominator intake, 3993820 iron heads, a 2.56 axle ratio and 10.5:1 compression ratio, I was getting 17 MPG on the highway and great throttle response. A very nice cam in my opinion.
The 427 in my 69 Corvette (bone stock 427/390 but with lower 9.5:1 compression ratio and a 3.08 axle) has the SUM-K1301 kit in it. I don't get quite the mileage I did with the K1300 cam (around 13-14 on the highway), but the throttle response it a little better than the K1300. It too is a nice all around kit.
We've since pulled the 396 out of the Camaro and installed a 427 (10:1 with almost 425HP on the dyno), and it has the SUM-K1302 kit in it. Although we've only run it on the dyno so far, the throttle response is great, but you have to keep the RPM's a little higher than the other two. We're estimating that with 3.31:1 gears (we're pulling the 2.56's out), the mileage won't be very good though. Probably in the range of 10-11 on the highway. But again, that's just an estimate.
I would recommend the SUM-K1300 or the SUM-K1301 for your engine if you want it to be a little more peppy. The 1300 would probably be equivilant as the stock 71-72 3904359 cam and the K1301 would probably be a step up to that. In my opinion, the 1302 would be way too much for your engine so I wouldn't recommend that one.
By the way, the Summit house brand is apparently manufactured by Crane. More info HERE.
Ed
Personally I like to stick with one company be it Comp Cams, Lunati all the way to Summit or Jegs in house cams.
There are only a few cam core blank makers and all the cam companies buy there blanks from them. They then go on to machine the blanks to specs they believe most people will want.
I can't overstress this enough that there are cams made out austempered "concrete" as I like to call them with a thin layer of hardened material on the lobes, then there are billet steel cams, these are the only cams I would put in any motor.
Comp Cams at the time I built my 427ci a couple of years ago made me a custom billet cam very close to the XR286R solid roller they sell off the shelf with only a few changes like small base circle and slightly higher lift for only $40 dollars more than the off the shelf cam they make which I believe is not billet steel.
They ask you a bunch of questions and all the info is marked on the end of the cam by hand with a dremel. I can't stress enough to spend the extra and get a billet cam be it flat tappet or roller. Below gives you some idea of what I am talking about in pics. This goes for anyone building a motor
Which one would you want in your motor ?
And here's mine I didn't know whether to use it or hang it on the wall
I really fascinates me that the roller lifter can follow these cam lobes @ 7500 RPM as they look almost vertical off the center of the cam
Just looked -9 is Steel Billet Core -9W is Welded Steel Billet Flat Tappet, you'll have to call Comp to ask them what that means
By the way, I knew someone was going to bring up the fact that the Holley Street Dominator isn't a very good intake, but I had it handy when I went from my cowl induction hood back to the stock SS hood. I was originally running a Weiand Stealth and a Holley 3310, but when I changed the hood it hit the top of the carb. So I used what I had on hand. A Holley Street Dominator and a Holley 6210. It wasn't the greatest combination in the world, but it was actually better than I throught it would be! I still had great throttle response and 17 MPG to boot. I won't complain about that!
Ed
