crocus cloth
Old Jul 23, 2012 | 05:05 PM
Jacobs81's Avatar
Jacobs81
Default crocus cloth
Hi everyone, I'm rebuilding my calipers and my book says to cleanup the bores using "crocus cloth". I am having a hard time finding it at any of the stores i've tried and am wondering if there is an alternative such as emery cloth that will work without ruining my calipers. my calipers are stainless sleeved and are in pretty good shape, I would just like to polish them before installing the new seals.
Old Jul 23, 2012 | 05:14 PM
gbvette62's Avatar
gbvette62
Crocus cloth is finer than emory cloth, and designed for polishing.
3M makes it in sheets. I would check with an "industrial supply company", basically a hardware store for manufacturing plants and contractors. If you can't find it locally, email or call 3M, and ask them where you can get it.
Old Jul 23, 2012 | 05:20 PM
pws69's Avatar
pws69
Crocus Cloth is EXTREMELY fine - Emery cloth WILL be coarser - and I wouldn't recommend using it. I would clean them up with brake solvent and see if you have consistent wall finish - and if so, leave it. Typically, lots of use will wear a shiny ring in the area where the piston rubs. Even a little shininess is likely OK if there is not ridge - that's the evil one!
Old Jul 23, 2012 | 05:21 PM
72SLEEPER's Avatar
72SLEEPER
Grangers if u haveone or order of net prolly cheaper
scottyp99's Avatar
scottyp99
If you know anybody who works at a machine shop, they have stuff like that.
Keep the shiny side up!
Scott
Old Jul 23, 2012 | 05:33 PM
noonie's Avatar
noonie
You can just use a scrubby with solvent, water if need be, like the green that is common, but white is a lot finer.
As mentioned, it's purpose is just to polish lightly.
Old Jul 23, 2012 | 05:49 PM
RatRacer's Avatar
RatRacer
I use green scotchbrite.
Old Jul 23, 2012 | 08:04 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
#0000 steel wool. It is not as hard as stainless. I use it to polish chrome.
Old Jul 23, 2012 | 08:54 PM
redvetracr's Avatar
redvetracr
with some elbow grease
Old Jul 23, 2012 | 09:13 PM
Indiancreek's Avatar
Indiancreek
I have some, if you message me your address I'll send you some. I use it in the machine shop for different things. I also use it for action jobs on guns.
Old Jul 23, 2012 | 11:30 PM
Vette5.5's Avatar
Vette5.5
I agree you can likely use an alternate type of abrasive for clean up. One thing I do know about crocus cloth, is it's really tough stuff. Used it as a kid, to sand rough rocks smooth, for collections.
Old Jul 24, 2012 | 06:38 AM
Indiancreek
A sheet of it lasts a long time. It has something in it that acts like a polishing compound that puts a very nice finish on metal.
Old Jul 24, 2012 | 09:38 AM
billla's Avatar
billla
St. Jude Donor '14
www.goodson.com
Old Jul 31, 2012 | 04:39 PM
Jacobs81's Avatar
Jacobs81
Thanx for the replies, i appreciate it. I ended up using a scotchbrite on them and it cleaned them up pretty good. again thanx.
To crocus cloth
